Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Hey Guest💡👉 We have just launched our new Dealer Directory and review service Find out more now
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
disconnect battery (negative) for half an hour, then reconnect and go for a drive, if done properly you will need a radio code. well worth doing from time to time.
As said, disconnect battery for 10 mins or so (ignition wont make any difference).
Once you reconnect the battery put all the windows down then back up so they can learn where the stops are. As said you will need radio code (if you have standard redio)
please tell me why you would reset your ecu in the first place? unless theres some major faults you have rectified and dont have acess to diagnosis equipment and need to delete. at the end of the day your engine wears the more you drive it but theres nothing you can really do about that.
