Eml and power loss.
scott180
434
portsmouth
Hello guys I'm just wondering if any of you could help, my cupra recently came off a dyno and produced 210bhp and 250lb/ft although it was mapped to 225bhp and 285lb/ft 18months ago and had a full service 3 days before the run. Just had it on obd and have 3 codes but can't seem to understand what's going on. The codes are P0036, P0340 and P0413. Any help will be appreciated :)
Bigjohn84
Intagram / johnyoung84
May 5, 2015
2,330
P0036/ - Oxygen (Lambda) Sensor B1 S2: Heating Circuit: Malfunction / Open Circuit
Check Oxygen (Lambda) Sensor Bank 1 Sensor 2 Heating Circuit
P0340 - Camshaft Position Sensor (G40): Malfunction
Possible Causes
Wiring from/to Camshaft Position Sensor (G40) faulty
Timing misaligned
Possible Solutions
Check Wiring from/to Camshaft Position Sensor (G40)
Check Camshaft Position Sensor (G40)
Check Timing
P0413 - Secondary Air Injection System Switching Valve "A" Circuit Open
Bigjohn84
May 5, 2015
2,330
Change lambda sensor after cat so post cat B1-S2
Change camshaft position sensor, left side of engine under left cover beside belt
Delete SIA System
Bigjohn84
May 5, 2015
2,330
All dynos are different there will never be one that gives out the same reading, are you stage 1 or stage 2? Stage 1 would be 210bhp in a AUQ 180, stage 2 would be 230/240bhp, it's prob just the dyno you were on.
scott180
434
portsmouth
Thank you for the response :) she's stage 2 and ran 225bhp on dyno dynamics rollers originally. I'll change the lambda and camshaft sensor then and see if they go. Won't a sia delete throw a fault code?
