Sep 16, 2023
Hi all,
I have installed the auto light switch and rain/light/humidity sensor in my Leon fr 2015. I wondered if anyone has an “idiots” guide to the coding needed to make them work please. I replaced the humidity only sensor as I have climate control already.
I have an OBDeleven pro just arrived.
I have also just got the auto dim rear view mirror I need to install and code.
Any help would be great ?
Check this. It's for VCDS but it's almost the same
Module 5F - adaptation- Car_Function_Adaptations_Gen2:
Stop the as follows:
17) menu_display_wiper: Enabled
18) menu_display_wiper_clamp_15_off: not enabled
19) menu_display_wiper_over_threshold_high: Enabled
20) menu_display_wiper_standstill: not enabled
21) menu_display_wiper_after_disclaimer: not enabled
Module 5F - Adaptation-:
22) Car_Function_List_over_threshold_high: Enabled
23) menu_display_wiper_standstill: not enabled
24) menu_display_wiper_after_disclaimer: not enabled
I believe this is what I followed when I did mine....
go to 09 Central Electronics - Adaptations, now follow the next 3 pictures (check that you have the same values as those marked with an X). Code 31347
For wipers, now go to 5F Infotainment Module – Adaptations and follow the next 2 pictures (check that you have the same values as those marked with an X). Code 31347
required for menu option...
After that go to other menu Vehicle menu operation
Red marked need to be change
After you have finished with this mod need to reboot Infotainment unit by holding down power button until it turns off and on again and you should see the following....
Hope this helps
Great thanks for the advise guys very much appreciated and all is working now ??
Now I can’t for the life of me get the coming home and leaving home to work. I’ve even paid for the app activation on OBDeleven and still nothing.
any ideas guys?
Thanks for your help ??
Hi all,
Hey bro, any chance you have the part numbers for the sensor and switch? have seen a few for sale and would just like to confirm 100% before purchasing - also have a 2015 FR with the climate control
Hi went for Rain Sensor 5Q0955547B and Headlight Switch 5G0941431AF
Followed the instructions above and all seems well so far
Hi. Just bought a 2013 SE which has basic manual mirror, no sensors on the windscreen, is it still possible to add auto lights?
You might be better getting a Chinese auto switch with the sensor otherwise you need a new windscreen and other stuff
Hi
I would like to upgrade my 2017 Leon ST FR to Autolights and wipers. I don't have access to coding stuff but was wondering from these threads if the following would work.
For Autolights I was going to just by the Chinese Switch with its own sensor. This appears to work well for those that have fitted it. I noticed a few references that if you fit the rain sensor (I think 5Q0955547A is the one for facelift model) the autowipers just work without coding. It appears you only need coding the enable the autolights (if you use an actual proper SEAT light switch). If I have fitted the Chinese light switch does the fact the rain sensor also has the light sensor mess anything up if you don't use it?
Hope that makes sense.
Regards
Hi
Regards
Better doing it properly and just getting it coded by someone
Hi
Regards
just do it properly and have someone code it or code it yourself with an OBDeleven it’s easy, the Chinese switches cause fog light issues
