Snoopie
Impossible
Feb 5, 2006
349
Enfield
When at Idle.... The car is fine, once moving the car is fine.
But when your stopped (idle) and you rev the car hard'ish' the engine blips slightly. Someone mentioned it could be a missfire etc....
Is this a common problem?
yes this could happen, used to happen to my old Golf GTI, found it to be a faulty spark plug lead, got it replaced and wallah..!!
dont hold me to it fella, it could be many things including perhaps a coil pack on its way out or faulty plug leads as i mentioned or even just a loose spark plug, best get someone in the know to give it the once over.. best a luck..
