swompz
24
Hey guys I've been chasing my tale on this one trying to work out what exactly the problem is as cant afford to throw money at the car needlessly.
I'm currently having an issue where the car will randomly & intermittently just die when i let my foot of the throttle whilst driving , eg waiting at traffic lights or coasting. might not happen for a day or so , or it may happen 5 times in a 20 minute commute. once the car has stalled out the eps & engine warning lights come on & remain on until the car has been switched off once or twice.
I've run a vcds scan & reset all fault codes , but obviously the issue persists.
Has anyone experienced similar or know what the likely cause is ??
TEST RESULTS LISTED BELLOW.
Chassis Type: 6L (6L - Seat Ibiza/Cordoba (2002 > 2009))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
Address 01: Engine Labels: 036-906-034-APE.lbl
Part No: 036 906 034 DG
Component: MARELLI 4MV 5953
Coding: 00071
Shop #: WSC 06402
VCID: 5AB1D10DC6089FF1404-4B34
VSSZZZ6LZ8R029955 SEZ5Z0G6051853
4 Faults Found:
18049 - Please check DTC Memory of A/C Controller
P1641 - 35-00 -
16955 - Brake Switch (F)
P0571 - 35-00 - Implausible Signal
17550 - Load Calculation Cross Check
P1142 - 35-10 - Lower Limit Exceeded - Intermittent
17961 - Barometric / Manifold Pressure Signals
P1553 - 35-10 - Implausible Correlation - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.lbl
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H05 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0002181
Shop #: WSC 06402 785 00200
VCID: 0103C6615B1EEC2961E-5140
3 Faults Found:
00526 - Brake Light Switch (F)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 84
Reset counter: 28
Mileage: 118981 km
Time Indication: 0
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 12
Reset counter: 65
Mileage: 119228 km
Time Indication: 0
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 12
Reset counter: 65
Mileage: 119228 km
Time Indication: 0
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6L0 820 045 C
Component: Klimaanlage 00.9
VCID: 2855BBC5C8E4FD61060-5124
1 Fault Found:
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q2 937 049 F
Component: 000A BN-SG. 2S36
Coding: 16396
Shop #: WSC 06402
VCID: 3F8700993D6A5AD957A-5124
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 AD
Component: 03 AIRBAG VW5 0010
Coding: 12339
Shop #: WSC 25090
VCID: 79F3AE8163CEB4E929E-5124
1 Fault Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
32-00 - Resistance Too High
Address 17: Instruments Labels: 6L0-920-xx3-17.lbl
Part No: 6L0 920 923 J
Component: KOMBIINSTRUMENT AGD V04
Coding: 00405
Shop #: WSC 00000
VCID: 356B62B10F5690898D6-5124
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 02QT GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 06402
VCID: 70E593A530B4F5A19E0-5140
Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb
Component: IMMOBILIZER AGD V04
Coding: 00405
Shop #: WSC 00000
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 10110
Shop #: WSC 00000
VCID: 2F6750D9ED0AAA59C7A-5140
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00016
Shop #: WSC 06402
VCID: 3D7B7A91376648C9456-4B02
1 Fault Found:
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
27-00 - Implausible Signal
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 6L0 035 186 C
Component: seat s04 GRO 6 37
Coding: 00401
Shop #: WSC 06402
VCID: 2C5D47D5DC1CD141E28-4B02
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End-------------------------(Elapsed Time: 02:41)--
Cool I try replacing the switch & take it from there i guess
I'd advise buying the latest switch from a VAG main dealer, it is a lot bigger at the connector end, so don't worry when it looks a lot different from what you are removing,and when fitting it, remember to leave the brake pedal up against its top stop. This is the opposite to how you fit the earlier versions, also, if you don't get it to fit correctly first time, these latest switches are "reusable" so you will be able to try fitting it a second or third time.
Hey guys , quick update ,
i Found the break light switch issue to be a blown bulb , I replaced cleared the tdc bank & brake fault now gone having run 3 consecutive scans in 3 days.
Ive also now replaced the MAP sensor & cleared down the fault codes again , thought Ide cured it for 24 hours but the eps lamp is back on & off along with the engine warning light intermittently after a slow rpm engine stall.
Having run yet another scan its still throwing up the same 2 faults
this Really sucks & need the car to be reliable for a long journey in a few weeks.
I was on Your way - started with MAP sensor, then brake sensor and problem was present - intermittent LIMP mode
Then I washed throttle body and problem solved (very cheap!!)
Good luck!
