smark32
66
Went for a top speed run (on private road) in my Ibiza pd130 (with custom map) Got to around 130mphchanged into 6th gear and the engine died! It lots all power. When I got back down to around 80mph I could feel there was a little power there but no turbo!
After this a turned the engine off and back on, then it came back to life! Turbo was back and everything was good again. :D
Is this my car, going into limp home mode? I did notice the oil temp was hotter than normal but not much.
Sounds like limp mode,
Possible problems
EGT,
Boost pressure
Best going back to where you got it mapped ;)
Agreed, ECU derated the engine till the air intake and or the fuel temp reduced - most modern cars have this safe guard, have you fitted a charge air cooler and fuel cooler??
try changing at 120mph most likely at peak power then, look at you dyno chart if you had it mapped on a rolling road. But re the problem it does sound if it went into limp mode. Also a remap wont increase your final speed a great amount, The standard turbo just not up to it.
I cant quite remember the speed but I had a run where I dropped my foot hard to the floor and my boost pipe blew off, which may have been at 3 digit speeds too on a private road. I didnt have that much road left but I kinda changed up and dropped it at probably those speeds from what I recall, to see how high I could get before having to slam on the brakes - the road involved has a crash barrier at the end, i.e. proper private road - and didnt fancy the impact enough to really push it ;)
