LOL - you got it in one, Proc!
I phoned my local
dealers up yesterday and told them that I'd had the engine management light come on, but that I'd already find out the fault codes and their meaning. I just wondered if the car was ok to drive until I get it in to them, and what the possible
problem could be.
He seemed a bit peeved but said that I should be ok to drive over the next week, as long as I wasn't planning on doing much motorway driving. However, he couldn't give any advice other than that one of the codes indicated a possible leaky pipe, which may also explain the 'system too rich' code.
I also told him that because I've been having the 3-early-morning-beeps
problem that a lot of you guys have, and it's now shown up on the fault as one of the codes ( faulty coolant sensor), I was thinking of just getting the coolant sensor replaced anyway and seeing if it fixed the other 2 codes. I mean, is it just some weird coincidence that I have no problems for ages and then 3 appear at once?!
The guy told me that I couldn't just have the sensor replaced, I'd have to have the expansion tank done at the same time - total cost, including labour and VAT, £50.
However, he did also say that they'd want to rig it up to their machine beforehand to check that they're not replacing something if it doesn't need it. The cost for that;
£25 if it's a 'quick test'
£65 if it's a 'longer test'
Are they pulling my plonker or is that fair? I was tempted to just get the cooolant sensor/expansion tank done for the £50 and see if it cleared the other 2 faults. Especially seeing as the 3-beeps indicates I've got a problematic sensor anyway and the work needs doing anyway. I don't want to shell out for a test at £25-£65 if it's not needed.
Any suggestions, please? Do I just get the sensor/expansion tank replaced at £50 and see if things clear, or do I pay Seat "£25-£65" for a test I may or may not need? Oh, and I guess my main question still is whether the car is still ok to drive while these faults are showing up? Apart from surging slightly (200-300 rpm) when the car is idling, it otherwise feels ok....
Cheers guys
