Dave_c85
395
I have a loud rattling noise.coming from my engine when idling. If I give the throttle the slightest pressure so the revs just go upbthe rattle disappears. It's dark out so not had a chance to look but any ideas? No eml and drives normally. Just happened this evening, sounds like a heat shield or something. Anything obvious I should look for? It's an LCR 225.
Sent from my C6903 using Tapatalk
Where is this located? Sounds exactly like a heat shield rattle.
All sorted, was a heat shield under exhaust, one of the bolts has gone I think so just bent it a few mm out of the way. Thanks.
