Engine temp
Petecog79
296
On my 2009 fr 170 tdi how long should it take for temp to hit 90 degrees as ive just drove from work and after 15 mins its only 50 it is minus 2 tho and I was averaging 25-30 mph, im new to the mk2 but is this normal, it also dropped temp as I pulled on drive
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
I think 15 mins at -2 driving at town speeds is normal. Is yours a PD or a CR?
If you do have a problem then it may be a sticky thermostat. Plenty of info on this in the Exeo section. Same engine (CR) but mounted the other way round and different plumbing.
Personally I think yours is normal.
Petecog79
296
Yes its my first diesel leon, its a cr, thanks for info ill monitor it over next week, though heater isnt as good as in my mk1 I have dual.climate control.
Nath.
Jan 1, 2006
8,620
16
Just so as you know, a diesel engine (especially a lean burning one) will take longer than a petrol engine to warm up. In fact if started from cold on a frosty morning and left ticking over it will probably never get up to 90. Diesel has a better Thermal efficiency, it basically burns cooler.
Petecog79
296
So if it not heating quick that will effect the heater temp then as it seems a bit cool today but was ok last week when.weather was warmer
Benzy
1,220
Plus if u have the heating on it takes heat from the engine thus causing it to take longer
Sent from my Nexus 7 using Tapatalk HD
figolovechild
Leon FR CR 170TDI
Sep 12, 2011
190
Glenrothes
Mine is the same. I have a 170CR and it takes ages to heat up. If I blow the heater full blast on hot then the temp gauge drops even more. I took it to dealership and they couldn't find anything wrong with it.
Nath.
Jan 1, 2006
8,620
16
