Lazy thermostat - keep an eye on yours!
M7R
Nerd...
Mar 27, 2008
327
Nottingjam
The wife took her 170 sport to the dealer yesterday as it has a lazy stat, now the temp has dropped the car really struggles to get warm, plus it just about reaches 90 on the motorway, but as soon as you slow down the temp drops, I had the same issue on my 1.9 A4, chanee the stat on that and it's like a rock now, glued to 90 no matter what I do with the in car heater..
So booked the wife's in via the telephone booking service at my local garage, Chilwell seat, the wife dropped it off and explained exactly the issue. When she went to pick it up they told her there was no issue and its a feature of the engine that it cools down..... So I paid a visit and politely told them the same as the wife did and explained where I worked etc.. And the car is now booked in for a new stat on Thursday.
The garage said it was the first they had heard of this problem, so can others check their cars and if needed report the issue to seat for a new stat, the main issue is slow to come up to temp, and once up to temp if you put the heater of full you can drag the temp back down to 70 deg or so.
Karl
Legohead
124
Hertfordshire
I'm sure others have reported this problem on here before and it was brushed off as a 'feature'
Mine does it too. Once on the motorway the temp can take ages to get to nominal (90) and with outside temperatures in negative figures, can drop back down to the quater mark. Can't remember what temp that is.
It seems to behave quite normally with the current climate ~ +7 degrees.
I'd be very interested to see how your car performs once the stat has been swapped out
M7R
Nerd...
Mar 27, 2008
327
Nottingjam
We shall see but I'm sure it's not a feature... As there's no way in hell it would have got the claimed figures on an emissions test if it can cool off so much.
Leodis
61
In last weeks cold weather it took a good 10 miles to hit 90', generally when I finally got to the motorway. After 20 miles on the motorway when I pulled off and slowed down the temp would drop to 70' before slowly coming back up over the next few miles.
I would expect a slight drop after pulling off the motorway, but expect it to jump straight back up again when cruising along in traffic.
Something not right here and will raise it with the dealers when the service is due in January.:confused:
M7R
Nerd...
Mar 27, 2008
327
Nottingjam
Nah it can't be right, it shouldn't cool down once its at 90, my a4 doesn't now I've changed the stat, the whole idea is it shuts off the water to the main rad unless its over 90, and the in car heater won't be that good at cooling!
Legohead
124
Hertfordshire
I'm with you mate. I absolutely don't think it's normal and I'm experiencing almost identical behaviour as Leodis. Never have I owned a car that cools down once its warmed up:confused:
I await the outcome of your dealer visit and will be booking mine in if changing the thermostat cures the issue!
M7R
Nerd...
Mar 27, 2008
327
Nottingjam
wife has just text me, they are placing the thermostat, so fingers crossed this make things a bit more stable!!! if it doesn't and it is a "feature" of the car then it's a bloody crap one! very poor engineering design that is for sure!
Loonyjuice
Newbie
Dec 5, 2005
117
Warrington
Managed to drag my temperature gauge back down from around 80 to 50 last week when it was -5 outside. Had the heater on high and was crawling down the M62 for a good 30 minutes.
It's not a cause for concern, unless you've lost all water from a split pipe - happened to me once. It's a combination of efficient diesel combustion, which is cooler than a petrol, efficient modern radiators and the fact that having the heater on high is sufficient to cool the water temperature because the heater is just another big radiator.
Deleted member 74601
It's amazing some of the bullshit they come up with.
M7R
Nerd...
Mar 27, 2008
327
Nottingjam
I'm sorry loony your wrong, while the stat is closed the water should only go round the engine, oil cooler and in car heater, the in car heater is a rad, but it is a small one, very small, and unless the air coming out is very hot and you have the in car heater set to hi there is a electronic valve which will partly shut the flow of hot water to the in car rad to regulate the temp in the car.
When the car water temp goes above 87 deg the stat will START to open, and be fully open by about 93 deg, this allows water from the block to enter the main rad at the front of the car, the water leaves that rad at very low temps, circulates back round the system and lowers the over all temp.. Once it's back bellow 87 the stat will be closed to raise the temp back up..
You will really struggle to drag the temp low using just the in car heater unless its very cold outside and you stick it on high with fans on full! My Audi won't budge now, and its not that wasteful on fuel compared to the exeo... In traffic it does better mpg! Ergo it must burn less fuel that exeo, less fuel means less overall heat, yet mine still reaches temp.
The coolant flow on the exeo is a little differnt to a4, but over Christmas I will map both to see if the exeo has a major design flaw, but I very much doubt it!
Exeo is back this eve so we will see what happens tomorrow when we are out...
MisterW
131
Surely it depends where in the circuit the temp sensor is ? if its in the main rad loop then it will behave as seen if the stat is working properly. My Exeo has always been like that , takes a long time to show 90 BUT the heater blows hot within a few mins so the temp in the engine/heater loop is ok.
M7R
Nerd...
Mar 27, 2008
327
Nottingjam
You would never put it where it would get a false reading, ie between stat and main rad, that temp sensor is used to control the fuelling of the car so why would you have warm water in the block, but have the computer think its still cold in the block?
MisterW
131
IIRC on my A4 there were actually 2 separate sensors , one feeding the ECU the other the temp gauge. They were both in the same place though. It could be on the Exeo they are in different places.
I can't believe that all of us have duff stats...
M7R
Nerd...
Mar 27, 2008
327
Nottingjam
I can check the parts list but I will put money on it using the standard temp sensor that all vag cars use, the 4 wire one where 2 wires got to the dash and 2 to the ecu, and no you couldn't get a different reading of each set of wires... There's only one sensor and 2 outputs.
Like I say I will see how it goes over the next few days,
mcdonald
On a dutch Audiforum is a special sticky topic about the engine temperature.
They say that the temperature should be 90 degrees at all time unless it's very cold and you're driving very fast. In this case the temperature can vary between 85-95 degrees.
It's also advised to have the thermostat and waterpump replaced when replacing the timing belt in case the thermostat is behind the belt.
As far as I know only the smaller SEAT Ecomotive cars (diesel) won't reach the 90 degrees during cold weather. This seem to be due to engine efficiency.
DWaldie
103
Mine behaves just like this. My last car (Mazda 6 CR143) hardly kicked any heat into the cabin by the time I got to work, but the engine was warm. The Exeo has a lovely warm cabin but cool engine :confused:
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
My 170 Exeo did this too. I thought it was wrong but didn't keep the car long enough to get it serviced anyway.
As said it would get upto 90 slowly and if you stopped/slowed it would drop and the heater would blow cooler.
mrkev
83
Yep, I have seen the same 'issue' where the temp takes ages to get to 90 and then randomly drops back to 70. But that was when the temp outside was well below 0. At the moment it's not doing it but it's about +5-6 degrees out there when I set off in the morning.
It seem like the stat is lazy and takes an age to shut. When I had an old escort ('92) and the stat failed on it (yes I know a completely different car), I could put the heater on high temp and fan on full. That stopped the engine overheating until I got the stat fixed so I know that the heater can have an affect on cooling, especially if you're taking in the air from the outside which can be well below zero. I noticed the rad on the Exeo is MASSIVE, and is probably over engineered for the UK, but I suppose it has to cope with all occasions like Spain's hot summers.
M7R
Nerd...
Mar 27, 2008
327
Nottingjam
Been out today, went about 10 miles down the road, was at the dual carriage way in a mile or so and already the temp was just off the stop, and I was driving normally. It's defo coming up to temp better at the moment (6 to 7 deg Amb temp) be it was up at 90 deg after about 5 mins at 60mph, also when hot it didn't cool down around town, and I could only drag the temp down with the heater on full heat, full fans and every vent open! And that was at idle... With the heater set to auto, econ and 23 deg it wouldn't budge from 90, so it looks like it could be the same lazy stat problems the audis have..... If your still wont be stable I would push to have the stat changed, it was Nottingham pentagon seat Chilwell that did mine under warranty,
Karl
