seatstu
209
I have a mate with a Ibiza 1.4 X reg with the above error code.
Anyone got any ideas. The error list says Engine RPM sensor - no signal - intermittent fault.
Aparantly there are more than one RPM sensor.
the explanation i have is that code 16706 ignition/distributor engine speed input circuit- no signal. im not sure what that means but i hope it helps all the same. woz
http://wiki.ross-tech.com/index.php/16706/P0322/000802
16706/P0322/000802 - Engine Speed Sensor (G28): No Signal
Possible Symptoms:
Engine shuts off
Engine doesn't start
Speedometer inoperative
Glow Plug Indicator Lamp (K29) flashes
Possible Causes:
Engine Speed Sensor (G28) loose
Engine Speed Sensor (G28) faulty
Possible Solutions:
Check Engine Speed Sensor (G28)
Special Notes:
The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position.
