Hi, I have just purchased an Exeo, it was from an auction, so I know no history on it. The boot inner trim was removed and the boot wouldn't undo from the door handle.
The last MOT failed because the boot wouldn't stay shut when driving. It seems that this has been rectified by doing something to the mechanism so that now it is partially disabled. You can manually open it by flicking the white plastic lever on the lock mechanism. The car came with a handy stick in the boot for this purpose
I can't work out what they have done. I have read some threads for Audi A4's (which I believe this is heavily based upon) which suggest that there is a steel rod going from an actuator to the white plastic lever, but I cant see this. I also cant find any reference to this in the parts catalogue for the Exeo.
I don't mind buying a new lock mechanism, but I want to understand if something else is missing. Should there be an external actuator, or is it integral on this type of lock mechanism?
I have had a play with my voltmeter and there is permanent 12 v going to the lock mechanism and when I pull the door handle there is a momentary voltage down a switch wire, so it appears that the fault is with the lock assembly.
