external temp sensor
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
this is the sensor in the n/s front bumper on the lc. mine seems to read 2-3 degrees warmer than it should.
does this sensor have any use other than the beep warning and dash display?
does the ecu use this temp reading in the choke cycle at start up?
cheers in advance
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
it'll be used for air con as well
but you can locate it elsewhere if you think it's getting heat radiated from other sources
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
hmmm this is from a cold engine as well as warm. other day it was 4 onstart up then after 3 minute idle and 200 yds later it was 2.5 ? thing is i was scraping frost off the window! mates fto reads 3 degrees colder . nothing on vag com so it hasnt failed but..?
funny tho.. when my water pump started dying i noticed the heater seemed cooler, maybe ive got used to it . think i need a new sensor.
not linked in the choke cycle tho?
