fault code mk1 seat leon tdi
AHRacing
20
my fault reader displays the following (u380 scanner)
It reads: / 1.DTC / FAULT: 01 PEND: 00 / N/A 01/01
Also under 3. I/M / MISFIRE N/A / FUEL READY / CCM READY / CAT N/A / HCM N/A / EVAP N/A / 2AIR N/A A/C N/A / 02S N/A / HO2S N/A / EGR READY.
reset the light and it came back on
the car is running well with no apparent faults just the light is on
Has anybody came across this before
AHRacing
20
i have an iphone is there any apps for that
have tried to search for the code
there is some else who had the exact same thing but nobody else seems to no
Jan 22, 2007
2,074
some may say lala land....
i think so, but no idea. don't use fruit or access to see. search the app library should find something?
need a code we can understand to help better i'm afraid.
put a request in the vag-com request section and someone local can do a proper scan for you.
AHRacing
20
got got a code of p0672 which is liked to a glow plug but as i said the car is apparently running with out a problem
Degsy
212
Merseyside
I have had a glow plug light warning for the last 6 mths , been lazy and not sorted it yet. think they are about £10 / £12 from steelers each, pop em in and get warning reset and good to go.
D.
Jan 22, 2007
2,074
glow plugs are only used to start a car and only when temp i sbelow 3or5 degrees C outside, so no i wouldn't expect to make a difference when driving.
that code is a proper code.
search the tdi section and i'm sure you'll get a few hits.
one will be change all 4 of them before winter kicks in and you need them to start your car in a morning.
ross-tech wiki site will also advise on fault your getting as well
AHRacing
20
Just used the link for ross tech which sent me off to tdiclub com where the id a full breakdown of the glow plug circuit.
