Mar 6, 2023
Cardiff
Hi,
A while ago I bought a 2020 Cupra Formentor (310) from a salvage that was in a front in accident where airbags went off. Structurally and mechanically car was fine and is working perfect.
I’ve done all the repairs and replaced airbags/seatbelts (done this through a independent garage who was recommended by Seat) however with his Vag-com could not erase the airbag codes. We did go through it together and the code were not active but sporadic.
I have a Bluetooth reader and I’m unable to remove the codes; before taking it to the dealer I was wondering if there is anything that was missed or any easy checks to troubleshoot.
ECU report below. Not sure if linked but aware of the part protection with adaptive cruise, will be attempting to reconnect original from old bumper tonight.
Thanks,
Armen
Detailed ECU info
CAN network gateway
Part #: 5WA907530N
Component: GW2020 High
Software version: 7310
ASAM/ODX identifier: EV_GatewMQB2020
Coding: 0000808D0F00000000000000012301137101610B02000100030100000001010000000000000000000000000000000000 (hex)
Fault codes:
15360512 Manufacturer-specific code
2494569 Manufacturer-specific code
8482819 Manufacturer-specific code
Engine
Part #: [none]
Component: [none]
Software version: [none]
ASAM/ODX identifier: [none]
Coding: [none]
[Failed to check fault codes]
Engine (2)
[ECU not present]
Engine
Part #: 5FF906259
Component: R4 2.0l TFS
Software version: 0003
ASAM/ODX identifier: EV_ECM20TFS0205FF906259
Coding: 0B2540322466050B300C0000000000000000000000000000 (hex)
[No fault codes]
High beam assist
[ECU not present]
Transmission
Part #: 0GC906557AB
Component: GSG DQ381
Software version: 4161
ASAM/ODX identifier: EV_TCMDQ381062
Coding: 0014 (hex)
[No fault codes]
ABS
Part #: 5WA614517BE
Component: ESC
Software version: 0127
ASAM/ODX identifier: EV_Brake1ESCEPBMQB37W
Coding: 56046A9956206A715278AC0635CA65A64A520B508AC8670801BCB635019FF900002814 (hex)
[No fault codes]
Brake booster
Part #: 5WA909059G
Component: EBKV
Software version: 0111
ASAM/ODX identifier: EV_BrakeBoostG2BoschVW37W
Coding: 5003C5009600007BEFBDF7DE000049922449922400 (hex)
[No fault codes]
Parking brake
[ECU not present]
Power steering
Part #: 5WA907145H
Component: BASGEN1MQB37
Software version: 1030
ASAM/ODX identifier: EV_SteerAssisBASGEN1MQB37
Coding: 0000000000000001000102010100010000000101010101 (hex)
[No fault codes]
Steering angle
[ECU not present]
Active steering
[ECU not present]
Steering wheel
[ECU not present]
Airbags
Part #: 1EA959655CH
Component: VW40Airbag
Software version: 0166
ASAM/ODX identifier: EV_AirbaVW40ALVVW38X
Coding: 88CC008000C0C000000000000000000051540000205400004000F68000930065 (hex)
Fault codes:
9446675 Manufacturer-specific code
9444115 Manufacturer-specific code
9443859 Manufacturer-specific code
9437201 Manufacturer-specific code
9437211 Igniter for Driver's Airbag
9445395 Manufacturer-specific code
9437723 Igniter for Passenger's Airbag
9438481 Manufacturer-specific code
9438225 Manufacturer-specific code
9438737 Igniter for seat belt tensioner; Driver's side (short to ground)
9438747 Igniter for seat belt tensioner; Driver's side
9438993 Igniter for seat belt tensioner; Passenger's side (short to ground)
9439002 Igniter for seat belt tensioner; Passenger's side CLEARED
9439003 Igniter for seat belt tensioner; Passenger's side
9439505 Manufacturer-specific code
9439249 Manufacturer-specific code
9439258 Manufacturer-specific code
9439259 Manufacturer-specific code
9682160 Manufacturer-specific code
9682161 Manufacturer-specific code
9439514 Manufacturer-specific code
1075977 Manufacturer-specific code
1075464 Manufacturer-specific code
9447424 Manufacturer-specific code
9466352 Manufacturer-specific code
1075461 Manufacturer-specific code
1075462 Manufacturer-specific code
1075463 Manufacturer-specific code
1075465 Manufacturer-specific code
16717825 Manufacturer-specific code
Instrument cluster
Part #: 5FA920790A
Component: KOMBI
Software version: 3440
ASAM/ODX identifier: EV_DashBoardVDDMQB37W
Coding: 24AC04417B9C06000181620B2000080800300000 (hex)
[No fault codes]
Infotainment display
[ECU not present]
Infotainment display (front)
[ECU not present]
Infotainment display (rear)
[ECU not present]
Infotainment display (rear left)
[ECU not present]
Infotainment display (rear right)
[ECU not present]
Infotainment display (roof)
[ECU not present]
Navigation
[ECU not present]
Voice control
[ECU not present]
Radio
[ECU not present]
Digital radio
[ECU not present]
Satellite radio
[ECU not present]
Sound system
[ECU not present]
Media player
[ECU not present]
Media player
[ECU not present]
Media player
[ECU not present]
Media player
[ECU not present]
TV tuner
[ECU not present]
Digital TV tuner
[ECU not present]
Infotainment system
Part #: 5FA035862K
Component: MU-O-ND-EU
Software version: 1896
ASAM/ODX identifier: EV_MUOIMQB37w
Coding: 43161008000100000000000000000000000000000000000000 (hex)
[No fault codes]
Infotainment system 2
[ECU not present]
Telephone
[ECU not present]
Immobilizer
[ECU not present]
Towaway protection
[ECU not present]
Headlight aiming
[ECU not present]
Left headlight
[ECU not present]
Right headlight
[ECU not present]
Tire pressure monitor
[ECU not present]
[ECU not present]
Heater & air conditioning
Part #: 5WA907727P
Component: Climatronic
Software version: 0340
ASAM/ODX identifier: EV_ACClimaBHBVW38X
Coding: 000100040211120010100010101011110000112100200000000000000000 (hex)
[No fault codes]
Rear heater & A/C
[ECU not present]
Auxiliary heater
[ECU not present]
Auxiliary heater
[ECU not present]
Parking sensors
[ECU not present]
Parking/steering assist
Part #: 5WA919298A
Component: PLA 12K Kanal
Software version: 0230
ASAM/ODX identifier: EV_EPHBO2CVW3800000
Coding: 8300026011 (hex)
[No fault codes]
Auto-leveling suspension
[ECU not present]
All-wheel-drive system
Part #: 5WA907554N
Component: 4Motion
Software version: 0656
ASAM/ODX identifier: EV_AllWheelContrHA1VW37X
Coding: 0001 (hex)
[No fault codes]
Suspension
Part #: 1EA907376B
Component: DAEMPFUNGS-SG
Software version: 0456
ASAM/ODX identifier: EV_DCC3CONTITEMIC
Coding: [none]
[No fault codes]
Central electronics
Part #: 5WA937086F
Component: BCM 37W BOSCH
Software version: 0159
ASAM/ODX identifier: EV_BCM37w
Coding: [none]
[No fault codes]
Driver's door
Part #: 5Q4959593H
Component: TSG FS
Software version: 0691
ASAM/ODX identifier: EV_DCU2DriveSideMAXHCONT
Coding: 00351820D201020000001020 (hex)
[No fault codes]
Front passenger's door
Part #: 5Q4959592H
Component: TSG BFS
ASAM/ODX identifier: EV_DCU2PasseSideMAXHCONT
Coding: 00351020DE01020000001020 (hex)
[No fault codes]
Trunk
Part #: 5Q0959107AB
Component: HDSG-Modul
Software version: 0272
ASAM/ODX identifier: EV_DeckLidCONTIAU736
Coding: 3F08 (hex)
[No fault codes]
Driver's seat
Part #: 5WA959760H
Component: MEM-FS
Software version: 0361
ASAM/ODX identifier: EV_SCMDriveSideCONTIAU736
Coding: 01789A000000A0408803010101010000000000212100000000000000215000 (hex)
[No fault codes]
Ignition authorization
Part #: 5WA959436C
Component: Kessy IOBOX
Software version: 0706
ASAM/ODX identifier: EV_Kessy37w
Coding: [none]
[No fault codes]
Adaptive cruise control
Part #: 5WA907572B
Component: ACC Bosch MQB
Software version: 0395
ASAM/ODX identifier: EV_FRONTRADARBOSCHVW380
Coding: 0A03007D407740451247400000400005AE4020000000000000000000000000 (hex)
Fault codes:
00617 Airbag Deceleration Sensor - Left (G104)
00628 Actuating Variable Control
00747 Front Battery Temperature Sensor (G52)
Lane-change system
Part #: 2Q0907686D
Component: HRE_Master
Software version: 0276
ASAM/ODX identifier: EV_HREntryHellaGen3Mstr
Coding: 9A9545D0 (hex)
[No fault codes]
Back-up camera
Part #: 5WA980556C
Component: RV eCompact
Software version: 0314
ASAM/ODX identifier: EV_CamSysRVCCompaFicos
Coding: 04033200843000 (hex)
[No fault codes]
Telematics
Part #: 5WA035284C
Component: OCU3HMQB37W
Software version: 0142
ASAM/ODX identifier: EV_OCU3HMQB37W
Coding: 043160009068A8209025460061502E07 (hex)
Fault codes:
12866049 Manufacturer-specific code
Structure-borne sound
Part #: 5FF907159A
Component: SAS-GEN 2.5
Software version: 0001
ASAM/ODX identifier: EV_SoundActuaGen2AU64X
Coding: [none]
[No fault codes]
Driver assist front sensor
Part #: 5WA980653A
Component: MQB MFK 3.0
Software version: 3129
ASAM/ODX identifier: EV_MFK3ValeoMQB
Coding: 00030918216CC040109E48801020002001418000000000000000000000000000 (hex)
[No fault codes]
Steering column lock
Part #: 2Q0905861B
Component: ELV-MQBB
Software version: 0040
ASAM/ODX identifier: EV_ELVMarqMQBA0
Coding: 0800000000000000 (hex)
[No fault codes]
Transmission 2
Part #: [none]
Component: [none]
Coding: [none]
[Failed to check fault code]
Light control 2 (left)
Part #: 992941571AE
Component: LED1L
Software version: 9202
ASAM/ODX identifier: EV_LLPGen3LKEBODPO68X
Coding: [none]
[No fault codes]
Light control 2 (right)
Part #: 992941571AE
Component: LED1R
ASAM/ODX identifier: EV_LLPGen3RKEBODPO68X
Coding: [none]
[No fault codes]
Just an update, the Airbag control unit also had to be sent to be reset. I used Crash Data, quick turnaround, would recommend.
