Fault with steering assistance module
Dec 6, 2019
Hello people
I'm fairly new to coding so bare with me please
I have an Ibiza FR 2020 1.6 MPI
I was trying some adaptations in the steering assistance module (44), after the changes I closed the ignition then turned it back on and was about to drive, but the steering wheel became very heavy, as if power steering isn't working.
The feature that I was fiddling with was the steering response, I changed it to comfort and saved, and since then a lot of errors appear in the full scan, a couple of these errors stay after clearing errors.
And finally I can not change anything in the steering assistance module, whenever I try to change anything and apply --> (22) function cancelled, marginal conditions have not been met.
Now I want to know what exactly do you guys want to see from the logs, because I extracted the history file and it's fu***ng huge ?
Example of the faults:
Bonus questions
Something I did in the dashboard module (17) made me turn off ignition with 2 clicks on the engine start button rather than 1. Although I reverted the changes I made, it is till turned off with 2 clicks. Any idea where to take a look at this?
Has someone achieved dipping mirror in reverse without memory seats on the ibiza?
Another issue i face with the optical parking system, it appears for 2-3 seconds then disappears.
And last but not least, I want to turn off my yellow rear turn signal and make the LED only to blink. I did that successfully, but my problem is it keeps bringing up an error on my display to check the signal. Is there a way to disable this error?
Dec 6, 2019
Here is the latest error log
OBDeleven data log
Date: 2019-12-07 15:04
VIN: VSSZZZKJZLR020301
Car: Seat Ibiza FR
Year: 2020
Body type: Hatchback
Engine: CWVA 81 kW (110 HP) 1.6 l
Mileage: 3446 KM
03 Brakes 1
System description: ESC_base
Software number: 2Q0614517AE
Software version: 0242
Hardware number: 2Q0614517L
Hardware version: H13
Serial number: 08505898180808
ODX name: EV_Brake1BOSCHESPMQBA0
ODX version: 004036
Long coding: 530D4C573543CAAD32FFAC1634DB22A649124926226A245844 542254452C4465924892644456241A222A442AA22996431594 69C2A8
Trouble codes:
U111300 - Function limitation due to received malfunction value
Intermittent
Date: 2019-12-06 12:29:54
Mileage: 3330 km
Priority: 3
Malfunction frequency counter: 10
Unlearning counter: 213
Unknown ambient data: 0000000200A90000000001160000
static
Date: 2019-12-06 15:02:59
Mileage: 3337 km
Priority: 3
Malfunction frequency counter: 3
Unlearning counter: 173
Unknown ambient data: 0007000240A40000000100000000
U042300 - Invalid Data Received From Instrument Panel Cluster Control Module
static
Date: 2019-12-06 03:29:55
Mileage: 3330 km
Priority: 3
Unlearning counter: 163
Unknown ambient data: 0000000240B40000000001000000
44 Steering Assistance
System description: TRW_G4L_MQBA0
Software number: 2Q1909144M
Software version: 6041
Hardware number: 2Q1909144F
Hardware version: 611
Serial number: 1309413CB2K20320820
ODX name: EV_SteerAssisTRWG4LMQBA0
ODX version: 011016
Long coding: 010000000000000001000201010001010000010001
Trouble codes:
U112300 - Databus error value received
Intermittent
Date: 2019-12-06 03:29:43
Mileage: 3330 km
Priority: 6
Engine speed: 0 1/min
Vehicle speed: 0 km/h
System status: Reset
Terminal 15 status: On
Voltage terminal 30: 12.87 V
Power steering current consumption: 0.5 A
max.value: 16.5 A
End stage temperature: 33 °C
Steering assistance, engine output: 100 %
Engine angle: 276 °
Electric motor speed: 0 1/min
Steering assistance, target engine torque: 0.0 Nm
---: 0.9 Nm
static
Date: 2019-12-06 03:29:48
Mileage: 3330 km
Priority: 6
Vehicle speed: 50 km/h
System status: Cut_in
max.value: 16.5 A
Engine angle: 276 °
Steering assistance, target engine torque: 0.1 Nm
---: 0.8 Nm
B200FF0 - Internal malfunction
Intermittent
Date: 2019-12-06 15:23:04
Mileage: 3337 km
Priority: 5
Unlearning counter: 165
System status: Waiting for start request
Terminal 15 status: Off
Voltage terminal 30: 12.11 V
max.value: 0.5 A
End stage temperature: 215 °C
Engine angle: 0 °
---: 0.1 Nm
B7 Access Startsystem Interface
System description: VWKESSYMQB
Software number: 3Q0959435N
Software version: 1307
Hardware number: 3Q0959435N
Hardware version: 037
Serial number: 0520812458
ODX name: EV_KessyHellaMQBAB
ODX version: 004052
Long coding: 112E0E0703
Trouble codes:
static
Mileage: 3330 km
Priority: 6
Malfunction frequency counter: 2
Terminal_15_Kessy_specified_value: On
Terminal_15_Kessy_actual_value: On
Terminal_15_central electric_actual_value: On
Terminal_15red_Kessy_specified_value: On
Terminal_15red_Kessy_actual_value: On
Terminal_S_Kessy_specified_value: On
Terminal_S_Kessy_actual_value: On
Terminal_S_central electric_actual_value: On
Terminal_50_Kessy_specified_value: Off
Terminal_50_Kessy_actual_value: Off
ZAT_pressed: Off
Park selector lever position: Engaged and locked
Request active: Condition not met
Enabling steering column lock: Condition not met
Enabling immobilizer: Condition not met
No active error mode: Condition met
Key signature validity: Condition met
---: 12.851 V
Driver information key position copy workshop: not active
Driver information, roll warning: not active
Driver information, emergency shutdown: not active
Internal_key_position: no_message
Driver information comfort switching: not active
Vehicle speed: 0.0 km/h
Engine speed: 0.0 1/min
---: Vehicle unlocked
Approach to the inside: not active
Actuation to the inside: not active
Approach to the outside: not active
Actuation to the outside: not active
Pulling actuation, outside door handle: not active
Coding information: coded
Coding information: Not coded
Driver door: Open
Front passenger door: Closed
Left rear door: Closed
Right rear door: Closed
Active_LF_scans: Init
ID sensor 1 authentication, status: No response
ID sensor 2 authentication, status: No response
ID sensor 3 authentication, status: No response
ID sensor 4 authentication, status: No response
SPN_Byte 0: 0
SPN_Byte 1: 0
SPN_Byte 2: 0
