Faulty coolant temp sensor (G62)
tazsp1
Hi I have an ecl light lit up on dash and I plugged a diagnostic tester in and have found out that the coolant temperature sensor (G62) is at fault.I bought a new one from the Seat dealer and now I need to know where it is located on engine and will I lose alot of coolant when I take the old one out? Any help is greatly appreciated.Thanks:help:
tazsp1
Does anyone have any knowledge on the whereabouts the sensor is ? OR does anyone know if there is a maintenance manual written yet for the Altea.Thanks.
Jun 28, 2001
1,533
what is it for a start petrol or diesel???
if it diesel remove the air filter and down the side of the block looking in the engine bay from the fron of the car its on the right hand side with the connector facing backwards/sensor facing forwards, remove the clip and dont loose the o ring fit the new one and top up the coolant that you have lost.
do it when the engine is cold because 1 youll burn yourself and 2 youll looses more coolant!
clear the code and top up the system and bleed it..
tazsp1
Thanks Goble.It is a diesel 1.9TDI so the info you gave me is spot on.
Cheers Bud.
jumbo2504
I have an Altea 1.9Tdi (2005) which has been diagnosed by a dealer with the G62 fault. They want £99 for replacing the faulty sensor. The part number I've been given for my chassis is 06A 919 501 ( a 2pin grey/black sensor). My questions are:
  • Are the (German made) parts for sale on eBay good/adequate replacements for the original given that they are a third of the price charged by the dealer, i.e. £12 v £35?
  • Is it easy to fit this part?
  • Are there any post-fitting procedures apart from topping up lost coolant? i.e. specialist engine management resetting.
  • Apart from the advice to do the work "with cool engine", are there any other pre-requisites?
skordys
Have a problem with that sensor too.
Mechanic just replace it coz i had a hot engine start problems. He replaced twice and still nothing :)
Will replace it again tonight with original seat one - so will see.
btw its very easy job to do.:
just take engine cover and air filter out, then on your right hand side of engine is this sensor located.
u will loose a wee bit coolant but nothing serious so can be easy top up by water.
jumbo2504
My problem has been the amber ECS (Emission Control System) light intermittently coming on and going off. As I had been told that two of my glow plugs were not firing correctly, I opted to have all 4 glow plugs changed by the dealer (as I considered that job beyond me) and, if needed, to see if I could have a go at the coolant sensor myself. I've now ordered one on eBay but am not sure if it will come with the O ring and clip that I see in many item descriptions. I hope it is not going to be an ill-judged mistake.
skordys
my one cost £26 in motor shop. comes complete with oring and clips.
no idea how much that original seat one will cost but will keep u uinformed.
cheers
jumbo2504
Following my changing of the coolant sensor (£13 from eBay) it seems that the wiring and/or plug that is attached to the sensor itself is loose and/or damaged. I have established this by simply nudging the wires/connector and that makes the ECS light come on and go off.
Where could I get a replacement connector and can it be fitted easily? I don't know where the wires go to from the sensor. By the way my sensor was not located as described earlier in this thread. It is placed way down (and vertically) below the air filter to the left and front of the engine compartment. It was a bugger to get to after removing the air filter!
