Festoon Interior Bulbs... which ones for where!?!
LeonFR07DSG
400
Hertfordshire
Searched and found a few threads but none that specifically tells me what festoon led bulbs i need for which particular lights i am changing...
http://www.autobulbsdirect.co.uk/Festoon-LED-Bulbs/
found this site... are these the correct ones i need?
if so could someone be so kind as to direct me to which ones i need to change the interior lights at the front.. (think theres 3 bulbs in there on the roof) and the rear interior roof lights... and also the number plate lights...
thanks ! :clap:
AndrewJB
Aug 16, 2007
11,175
485
Maranello
Also want to know this :cartman:
I want to know what bulbs i need to replace Front Interior Lights , Rear Interior lights and Boot lights with LED's
b9rgo1234
50
5x 36mm festoons, 2 go in the sun visor lights, 1 in the light in the front, 2 in the rear light unit
2x 501 bulbs, also for the light in the front
I used a 44mm in the boot, its a little big but it fits :)
search fleebay for canbus 501 leds, if you dont use these the lights will stay dimmly lit when your driving
AndrewJB
Aug 16, 2007
11,175
485
Maranello
Do the Festoons need to be Can-Bus friendly aswell ?
My Ibiza Interior Festoon was always dimmly lit when driving
b9rgo1234
50
Only one of the bulbs need to be a canbus led, so yes you could put one festoon in the light in the front. I changed both 501s cos they came in pairs.
AndrewJB
Aug 16, 2007
11,175
485
Maranello
Right im a tiny bit confused now
501 Sidelight bulbs are sold as Can-Bus friendly , ive got 2 already in the headlights and work fine with me HID's
Whats confusing me is Festoon bulbs arent sold as Can Bus Friendly so ....
If i fit 5x Festoons and 2x 501 Can Bus's - Am i or Arent i going to get a warning light coming on?
b9rgo1234
50
Fit 5 standard led festoons and 2 501 canbus leds and all will be fine. I have that exact setup in my car just now, no lights staying on.
b9rgo1234
50
Yea Donnyboy that should work. As long as 1 of the bulbs is canbus friendly then the lights will go out when driving. The Canbus LEDs tend to be a bit brighter than the standard LEDs though.
Donnyboy
The Candy Man
Mar 15, 2005
1,558
renfrewshire
I see what you mean. The 501 bulbs will be the same light level and match each other and the 5 festoon bulbs will all be the same light level and also match.
Instead of 1 canbus festoon that looks different from the other festoons.
b9rgo1234
50
Standard festoon, with canbus leds. I got them off ebay, they have 2 leds on each side. I see in your link it had 1 larger one on the top which might be better.
And standard leds in the rear. One looks brighter but its just the picture.
