are the ngks not a agrade cooler then??
25 quid difference in total price, but if the ngk will be better and help with the high cfs then it doesnt matter
edit...just read the ngk are a grade cooler?? so which would be best?
just ordered some ngk. will fit them, run v power through and then re log
another one... exhaust blowing at rear box end somewhere... could this contribute?
new 003 and 020 logs running v power for quarter tank.
Code:
	Group A:	'003				Group B:	'020
		Engine Speed	Intake Air Mass	Throttle Drive	Ignition		Cylinder 1 Ignition	Cylinder 2 Ignition	Cylinder 3 Ignition	Cylinder 4 Ignition
	TIME			Angle Sensor 1	Timing Angle	TIME	Angle Delay	Angle Delay	Angle Delay	Angle Delay
Marker	STAMP	 /min	 g/s	 %	 °BTDC	STAMP	°KW	°KW	°KW	°KW
	0.01	2720	70	99.6	12.8	0.25	0	0	3	0
	0.55	2960	83.36	100	12.8	0.85	0	0	3	0
	1.16	3240	92.25	100	9	1.46	0	0	3	0
	1.76	3480	86.19	100	20.3	2.06	0	0	2.3	0
	2.36	3800	115.75	100	9	2.66	0	0	2.3	0
	2.97	4080	137.14	100	12.8	3.27	0	0	2.3	0
	3.57	4400	145.22	100	14.3	3.87	0	0	4.5	3
	4.17	4720	153.17	100	15.8	4.48	3	3	4.5	3
	4.78	5040	162.06	100	12.8	5.08	6	3	4.5	6
	5.38	5280	164.03	100	9.8	5.68	6	3	3.8	6
	5.98	5520	169.56	100	10.5	6.3	6	6	6.8	6
	6.59	5800	173.5	100	10.5	6.9	5.3	6	6.8	5.3
	7.2	6000	175.14	100	9.8	7.49	5.3	6	6.8	5.3
	7.79	6200	175.94	100	10.5	8.11	5.3	5.3	6	5.3
	8.41	6400	166.75	100	14.3	8.7	4.5	5.3	6	5.3
	9	6560	162.81	99.6	14.3	9.31	0	0	0	0
Tuesday	13	October	2009	20:47:46
06A 906 032 HN		1.8L R4/5VT         0002
and some 115 and 118
Code:
	Group A:	'115				Group B:	'118
		Engine Speed	Engine Load	Charge Pressure	Charge Pressure		Engine Speed	Intake Air	Charge Pressure	Charge Pressure
	TIME			(specified Value)	(actual Value)	TIME		Temperature	Solenoid Valve	(actual Value)
Marker	STAMP	 /min	 %	 mbar	 mbar	STAMP	 /min	°C	 %	 mbar
	0.01	2640	60.9	1020	1220	0.3	2720	30	86.3	1270
	0.6	2840	115	2010	1580	0.9	2960	30	86.3	1880
	1.2	3080	156.4	2380	2160	1.51	3240	30	86.3	2220
	1.81	3400	176.7	2270	2270	2.11	3560	30	85.9	2180
	2.41	3720	171.4	2250	2240	2.71	3880	31	85.1	2280
	3.01	4040	172.9	2260	2280	3.32	4200	33	84.3	2300
	3.63	4320	171.4	2160	2240	3.92	4520	34	84.7	2210
	4.22	4680	167.7	2140	2180	4.52	4840	36	85.1	2170
	4.82	4960	166.9	2120	2160	5.13	5120	37	84.7	2120
	5.44	5280	164.7	2100	2080	5.74	5400	39	85.1	2060
	6.03	5520	160.2	2090	2030	6.33	5680	41	85.1	2030
	6.64	5760	157.1	2060	1990	6.94	5880	43	84.7	2000
	7.25	6000	153.4	2030	1980	7.54	6080	45	82.7	1940
	7.85	6200	148.1	1960	1900	8.15	6280	47	80.8	1860
	8.45	6360	138.3	1900	1800	8.76	6480	49	78.4	1760
	9.05	6560	130.8	1850	1720	9.36	6640	50	78	1690
pull seems to be lower now??
Nearly there, James.
Could of been a bad batch of fuel you had in before.
Just need to get them below 6's now.
Reading this with interest as looks pretty similar to my logs,am on bp ultimate,no shell anywhere round here,tho i did put a tank of vpower in friday gone when i was down barnsley,gonna do plugs and treat her to new panel filter,where did you get your plugs mate?
BTW,how the hell do you get your logging figures to line up that well,mine look like a fekin dog's back leg.
plugs from sparkplugs.co.uk
cost 12 quid for 4 ngk bk7r.. 1 degree cooler than oem.
i just copy 2 groups from excel and paste them, with code in
Code:
 before and after the log.
Code:
	Group A:	'003				Group B:	'020				Group C:
	TIME			Angle Sensor 1	Timing Angle	TIME	Angle Delay	Angle Delay	Angle Delay	Angle Delay	TIME
Marker	STAMP	 /min	 g/s	 %	 °BTDC	STAMP	°KW	°KW	°KW	°KW	STAMP
	0.01	2880	76.81	99.6	20.3	0.3	0	0	0	3
	0.6	3200	113.58	100	6	0.9	0	0	0	3
	1.21	3520	118.22	100	9.8	1.51	0	0	0	3
	1.81	3880	129.11	100	6.8	2.11	0	0	0	3
	2.41	4240	140.64	100	9	2.71	0	0	0	3
	3.04	4560	149.5	100	12	3.32	0	3	3	2.3
	3.62	4880	156.72	100	9	3.92	3	3	6	5.3
	4.22	5160	166.67	100	12.8	4.53	3	3	6	5.3
	4.83	5480	170.78	100	12.8	5.13	3	3	6	5.3
	5.44	5760	173.75	100	9.8	5.74	2.3	6	5.3	5.3
	6.04	6000	176.5	100	10.5	6.34	2.3	6	5.3	4.5
	6.65	6200	175.69	100	13.5	6.95	2.3	6	5.3	4.5
	7.24	6360	170.78	100	13.5	7.55	2.3	5.3	5.3	4.5
new logs after week of v power and new ngk bkr7 plugs. throttle body reset done prior...
Code:
	Group A:	'115				Group B:	'031
		Engine Speed	Engine Load	Charge Pressure	Charge Pressure		Lambda Sensor	Lambda Sensor	Bin. Bits	Bin. Bits
	TIME			(specified Value)	(actual Value)	TIME	Current Value	Specified Value
	0.25	2760	110.5	1690	1500	0.01	0.961	1
	0.85	3000	147.4	2260	2020	0.55	1.008	1
	1.47	3320	171.4	2270	2220	1.15	1.008	1
	2.06	3680	175.2	2240	2270	1.76	1	1
	2.66	4000	173.7	2240	2290	2.36	1	1
	3.27	4360	172.2	2130	2250	2.97	0.953	0.953
	3.88	4720	169.2	2130	2200	3.57	0.906	0.93
	4.48	5000	167.7	2110	2160	4.18	0.914	0.922
	5.09	5280	163.2	2100	2110	4.77	0.914	0.914
	5.69	5560	159.4	2080	2030	5.38	0.899	0.906
	6.29	5800	157.1	2050	1990	5.98	0.891	0.891
	6.9	6000	151.9	2020	1940	6.59	0.875	0.891
	7.49	6200	147.4	1970	1900	7.2	0.891	0.891
	8.09	6400	141.4	1900	1830	7.79	0.891	0.899
	8.71	6560	130.1	1860	1770	8.4	0.906	0.922
Code:
	Group A:	'118				Group B:	'032
		Engine Speed	Intake Air	Charge Pressure	Charge Pressure		Lambda (add.)	Lambda (mult.)	Bin. Bits
	TIME		Temperature	Solenoid Valve	(actual Value)	TIME	Self-Adaptation	Self-Adaptation
Marker	STAMP	 /min	°C	 %	 mbar	STAMP	 %	 %
	0.3	2920	27	86.3	2080	0	-0.6	-0.8
	0.9	3240	27	85.1	2320	0.6	-0.6	-0.8
	1.51	3560	28	84.7	2210	1.21	-0.6	-0.8
	2.11	3880	29	83.9	2300	1.81	-0.6	-0.8
	2.71	4240	30	83.1	2300	2.41	-0.6	-0.8
	3.33	4560	32	84.3	2180	3.02	-0.6	-0.8
	3.93	4840	33	84.7	2160	3.62	-0.6	-0.8
	4.52	5160	36	84.3	2110	4.23	-0.6	-0.8
	5.13	5400	37	85.1	2060	4.83	-0.6	-0.8
	5.73	5640	39	85.1	2020	5.43	-0.6	-0.8
	6.35	5840	42	84.3	1960	6.04	-0.6	-0.8
	6.95	6040	44	83.5	1910	6.64	-0.6	-0.8
	7.55	6240	45	80.8	1890	7.25	-0.6	-0.8
	8.16	6440	48	79.2	1790	7.85	-0.6	-0.8
still highish cfs.. no where near as bad. any ideas what can be done further to reduce these, or whats casuing them
other views on these logs fellas?
boost looks ok to me
what about lambdas? look ok or lean?
whistling/whining still present on revs and full boost.
Looks much better now, James.
Looks a little lean to me though which could be causing the cf's. At 6k your AFR is 13.0977 whereas mine is at 12.2892 at 6.1k.
How old is the fuel filter? Could be worth replacing it.
fuel filter approx 2 years old mate.. last major i did.
whining could be dp gasket or turbo gasket, this cause to run lean?
noticed a drop in consumption also.
damo howd you work out if its running lean... pm across if you want. id like to learn that one
afr being air to fuel ratio im guessing...
so what would be classed as lean or rich?... whats the happy medium?
think i read somewhere but cant remember
