Flashing heated rear window button?
martin150
Had it on mine, was a battery charging issue as the alternator wires had snapped off the gearbox (common fault). Check the voltage at the battery as most of the electrical faults and some warning lights will occur if the battery is allowed to run down.
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
No issues here, i've had mine on for over an hour and no flashes at all. Could be a bad connection?
