flip key info thread
Oct 31, 2006
470
Lichfield, Staffs
New blade arrived this morning - just had it cut at local lock & key for £1.76. Works in the door (well, it goes in) gonna attach it to the key tonight.
How do I cut out the old transponder for the immobiliser from my spare key?
gazjones
it shouldnt need cutting out the old original spare key just prise open the key then remove the cream colours rubber and the transponder will be loose, was in mine and then swap it with you one in your flip key, some are stuck in but mine wasnt and my dads work van one isnt
gazjones
post 6 you can see the cream colourd rubber retainer in my spare non remote key
AndyC567
277
Mine was well stuck in...
My attempts to remove the Transponder resulted in dust, hence the start of my troubles..
Came out in about 1000 pieces :cry:
BJM
739
Houston, Renfrewshire
No rubber in mine either.Mine wasn't stuck in though t was just held in very tightly by a plastic clip. A bit of careful cutting of the clip with a craft knife and out it came.
gazjones
very fine blade to cut the glue out maybe not sure on anything else
