Flip key question!
Dec 31, 2007
1,479
Reading
have you tried it jimski, or are you just guessing because its got a dif number on the side? I always heard it didnt matter, I've used a couple now with my car which have all been fine.
Coalesy
Leon FR 20vt
Sep 16, 2008
76
Dronfield
seat only make them in either 433.92 (aka 433 or 434) or 315 mhz which is europe and usa i think, so in theory any bought in UK should work, same applies across all the VAG range me thinks :)
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
Iv tried both dudes, spare key in ignition on second click, get out the car, flip key in the lock, lock it manually, hold the unlock button and lock and unlock the door manually,
Didnt work, tried it a few times.
Any ideas?
Jimski
richellis
391
Cannock
Has any one got on to work tho????
There is acouple of 433mhz on the bay and I wanna bid, but need to be sure it will work.
can I get the imobiliser chip coded to my car, or do I need the one from the spare key??
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
Its about £32 + vat for a transponder to be programmed, thats what i got told earlier this week anyway
Jimski
Coalesy
Leon FR 20vt
Sep 16, 2008
76
Dronfield
Any ideas?
Jimski
Should work mate, unless they havent been coded in correctly??
ive used a golf blank key blade, got a fob (which are the same on VW as Seat) got the key cut then took it to my local dealer and got it coded in, works fine.
one other thing aswell, if anyone is getting there keys coded in remember to take ALL your spares as once another is coded it will cancel the others, it hink this is correct anyway lol
Coalesy
Leon FR 20vt
Sep 16, 2008
76
Dronfield
Yea 433 mhz will work or "should" work anyway, i have got mine to work, and you can get the imobilser coded to your car aswell at seat :)
Coalesy
Leon FR 20vt
Sep 16, 2008
76
Dronfield
Yes please :)
I was thinking of blanking my locks and having a spare flip fob in case the first dies, so I can get into my car!:p
Hi mate,
the part numbers for the flip keys are...
Key Blade (this is from seat dealer and wil have to be ordered for your car from dealer, will come cut to your key number)
- 6L0 837 246 B INB
the Fob bit is - 1J0 959 753 CT
and if you do what i have done and get a blank VW fliper of the bay then this is the part number for the little seat badge - 1M0 837 891 A JGT
thats the setup ive got, works fine for me but a few people are having problems..
hope this helps :)
Dec 31, 2007
1,479
Reading
coalsey... that p/n for the blade, is that just the blade, or the flip-section of the fob? I was told by my local dealers (seat, vw, skoda and audi!) that the blade does not come seperately?
Jimski, that sounds like the process I used, but I seem to remember i had to do mine a couple of times before it worked, not sure whether there's some sort of timings involved that I just happened to get right? I think there's been a few methods posted on here, might be worth having a search and keep trying for a bit longer? checked your battery is all fresh etc?
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
Right, well, spent the afternoon messing around with VAGCOM, seems the 2 fobs i have are not compatible with the vehicle, measuring blocks 13 on central convenience proved this, as it brings up a positive value when the either buttons are pressed if they are compatible.
I also erased the original fob through vagcom in order to start afresh and the method i have used previsouly worked for re-programming.
It also may be worth noting that the ECU's are told to only accept 1 key in some instances, there is an adaptation whereby you can alter the number of keys that the ECU can handle from 1-4 however this proved unsuccessful in my case. Unsure why.
I took all this from the Ross-tech website where it is documented extensively, some of the instructions are slightly different but the basic principle applies.
http://www.ross-tech.com/vag-com/cars/vw-remote-matching.html
Hope this helps some people to decide whether to do this etc
Jimski
Coalesy
Leon FR 20vt
Sep 16, 2008
76
Dronfield
yea it comes as the blade with the flip mech aswell, top bit of the palstic fob part if that makes sense :)
lc_allan
Northern Monkey
Sep 15, 2006
3,389
You can get blades off ebay for a couple of quid if you need a new one.
Some even come with spare pins.
