flip key
gazjones
i have search about this but there is so much about different cars
basically will a two botton 434mhz off a vw work with my car i know the frequency is the same ( 434mhz) the vw part no is HLO 1JO 959 753 AG FREQUENCY (434MHZ)
its un cut so just need that cutting then recoding? dont want to buy wrong one!
sorry for another post on it just there is thant many for different seats its very confusing
cheers gaz!
EdButler
713
Sheffield
Yep thats correct mate... Cutting should be a further £5
You recode in 2 phases - Alarm + Immobiliser. The Alarm is easy. IIRC you just put the new key in the ignition and then lock the doors with a different key.
The immobiliser will either be a dealer job or you have 2 options: Get your immobiliser code from VAG COM and get the dealer to provide your SKC. With this you can code it though VAG COM (although this method didnt work with mine)
Alternatively (much more easily) open up one of your current keys and get the immobiliser crystal out of it (looks like a small glass tube not connected to anything) Open up the front part of the flip key (or drll a 3mm hole like i did cos i couldnt get the bloody thing open) and pop the crystal in there.
Jobs a good en :D
gazjones
is that the same part no. as yours so the key will work with my car vw mk4 bora one
cheers ed
BJM
739
Houston, Renfrewshire
Having looked into this before I have saw 3 different flip type VW keys for sale, 433mhz, 433.92mhz and 434mhz. My key also says 433mhz - this is all very confusing!
Does the immobiliser crystal just sit in the key or does it need soldered in or anything?
gazjones
ivew seen more there are 3 and 2 button ones with virtually the same part no apart from the last 2 letters nearly bid on the wrong one! im going to try and win the key with the part no. at the top of the page and let peole know if it works! fed up of stabbing myself in the leg!
micky 32
630
Longford, Ireland
My mkiv Golf has a 434mhz key, as my key was getting rough looking i ordered a band new one from china ( www.vagproduct.com) for 32 euro delivered. It was a 433mhz key and will not work on a car with 434mhz but the immo works ok, well it didnt for me. I just swapped the board inside.
gazjones
well ive won the key i was on about for 19 quid so will let you know how things go with it
Triple D
Gaz you muppet, there was a thread on here recently that vivky and stu put up about coding there key for there new ibiza. have a butchers.
gazjones
yes thay have only coded there alarm putting the key in ignition then another in the lock and locking the car
was more trying to find out what key to get
gazjones
just read it again and makes sense now didnt untill ed posted up about the immobiliser chips! lol
gazjones
ive got my key now and just need a few bits of info
where can i get the key cut? as its different fron conventional keys
how do you remove the imobiliser crystal from the flip key so i can replcae with mine, got it undone as far as splitting it in half but what next?
cheers gaz!
gazjones
well lok like i have a nearly new vw key that is tamper proof meaning i cant remove the immobiliser chip and will need all 3 keys recoding along with ecu by the dealer as new regulations have come in not allowing just one key to be coded on its own!
