FMIC Question
Legojon
I only wanted a remap
5,284
2,714
Right I'm chilled , well not really but i've walked away from it tonight.
Apologies for the language folks, bit out of order on my behalf.
I'll see if I can find these brackets tomorrow.
I've found tinkering with the car either puts you on a massive high (when you achieve something and it all comes together) or a massive low (where everything that can go wrong does and you waste a load of time). I think anyone who's done any car diy gets it.
bigT's lcr
Delete. Beat. Repeat...
Feb 27, 2016
1,216
731
Leeds
I got my pal to give me a hand wiggling the bumper off. Didnt touch the lights, Just be carefull putting it back on as you can scratch the wings easly
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
Can anybody help with the location of the bolts/nuts for the brackets the bumper slides into on the wing ? I have found 2 x 10mm self tapping bolts that are in the middle of the wing but do not appear to have anything to do with the bumper. I would take pictures but have just dropped/broken my phone and dropped the inter cooler in short order.
Honestly think Im cursed.
bigT's lcr
Feb 27, 2016
1,216
731
Leeds
Take arch liner out and its an 8 or 10mm bolt on the front outer part of the arch about half way up
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,199
1,038
Kent
Its 2x 8mm nuts as I removed a pair yesterday.
Pull the bumper away from the arch gently as you undo the nuts as they have a tendency to rotate inside the plastic runner if you dont
Sent from my SM-G960F using Tapatalk
Reactions: bigT's lcr
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
Okay so in between work getting in the way I've been for a run around the block sans the bumper, all seems good. Front is back on oddly the bumper which didn't line up 100% has gone back marginally better (Im wondering if the car had a little biff on the nose at some point).
Not happy with the install so it all may come off again ....yes I'm <insert suitable adjective here>
