Footwell lights
caveo
Yea mate , was just yankin ya chain. Look at it this way your thread stayed at the top for alot longer than it would have.
But in all honestly a few subtle lights can be ok BUT if you can carryed away it will look kak
jordyboy004
Leon Cupra 1.8t 20v
Apr 4, 2008
239
Isle Of Wight
i have installed these. i brought some 6inch led strips off ebay. mine are red and i have them on a seprate switch. so when im parked up and have the doors open, i flick them on. i have 2 in the front and 2 in the back. pretty good if you have a car full too to flick them on. i have them off the battery so dont have to have the keys in the car for them to work.
scottg13
What is the best way to wire these lights up so they come on when door is opened? Or even when the car is unlocked like the courtesy light. Is it possible to turn them on manually also, even when door is shut? Thanks in advance guys
del 77
i wired mine up to a permanent live, then added a switch to the centre console, that way i could have them on whenever i wanted, without the engine running. Worked well when the car was at shows. Also had alloy chequer plate cut to fit the footwells so would reflect the lights.
scottg13
del 77, where abouts on the centre console did you put the switch?
del 77
i put the switch on the side of the centre console on the drivers side, under the dashboard, so it was hidden, and easy to get to while driving.
adm013
197
Edinburgh
I think the easiest way might be to tap into each of the courtesy lights on the door as all the switches are in place and it will work when doors are open.....
Andy
