Forge 007p
CupraR_Lad
515
Herefordshire
I decided to put my DV in reverse just now,took the car out for a test drive,and noticed the the car pulls hell of a lot quicker,and its boosting 15psi instead of 13? Humm...i dont see why it would boost more! i also put a new cable tie on the back of the boost gauge and made sure it was tight,maybe it might be that? :p
CupraR_Lad
515
Herefordshire
No mate! you can see the T pipe in the pic where its taken from!!
mrwookie
Big Daddy...
Mar 22, 2008
716
Cambs & Herts
Because rather than the pressure forced against the side of the valve it will be pressing against the bottom which might cause the valve to open slightly. This was a conversation I was having with my tuning shop...
No because there will be equal pressure against top and bottom of DV until throttle is released. Even Forge say it can be reversed safely. :)
Mar 29, 2007
1,207
Berkshire
Is that the case? I don't know that much about the induction side of the engine tbh... I've only had the dv the correct way round.
mrwookie
Big Daddy...
Mar 22, 2008
716
Cambs & Herts
007p in reverse is standard position sounds like a budgie being strangled but if you have a cold side relocation kit sounds rather nice in reverse. Ran mine in reverse for some time with cold side relocation. :)
