So would adding a better DV like the Forge FMCL007P require notifying the insurance company? (I don't think it would; just wanna check).bigboystoys said:Dump valves are designed to release unused boost pressure when lifting off the throttle which, due to decrease in back pressure, helps to keep the turbo spinning between gear changes for faster acceleration.
tell them to be on the safe side,they don't need an excuse not to pay up .jaybeee said:From http://www.seatcupra.net/forums/showthread.php?t=79282:
Also, what is going to be the difference is driving experience with this new DV compared to my existing standard one on my 03 LC? --> Smoother? Better acceleration?
its an INVISIBLE MOD, ie, THE INSURANCE COMPANY CANT FIND OUT!CupraSteve said:get a black DV then the insurance company probably wouldnt even tell the difference
I will not condone frauding insurance, and if you have wheels etc, or major engine work then deffo declare but some people even declare there remaps FFSits an INVISIBLE MOD, ie, THE INSURANCE COMPANY CANT FIND OUT!
, I personally think everyone should own a forge 007p as its a great product and you can get one from bigboystoys for around £70 delivered !!Ok, so only worthwhile if you get a remap done, i.e. there's absolutely no point in getting a new DV if the standard/existing one is causing no current issues?flashbsd said:It doesnt make any difference over the standard one, if you do remap its recommended to have one.jaybeee said:So, is it worth getting done on my standard 03 LC? (I'm not going for a remap)
