It looks like the best way to access the bulbs is to remove the headlamp units !! cos the access panels were made for v little hands !! [ lots of little attachments in and around the access panels] does any one have a better solution??
Yes I'm in same situation I removed all HID/LEDs from the Leon I had, expecting to put them in the EXEO but it looks like I might have to see if it is simples to remove the headlamp units !?@! - when the weather improves though. ............................I changed all 4 lamps to Osram Nightbreakers. When it came to trade the Exeo in, i tried to take them out, but i gave up! Keep on trying, or find someone with small hands!
Just replaced the orange indicator bulbs for some DIADEM style ones - they light up orange, but look clear/bluish when off. Bit of a fiddle and can confirm the need for small hands.
Still on the hunt for a LED DRL replacement.
So am I , but surely to do that you would need all or part of the xenon pack loom?? is the wiring /take off point's already there then?Still on the hunt for a LED DRL replacement.
I already use "can bus " loaded LED's and have done since I had my Leon 1P, but is the curcuit still there then so you can run DRL ??, which would be very useful [ I wondering has the EXEO headlight has two side lights per head light if one of the side lights can be change has a DRL!!]You can get bulbs with resistors in - or add resistors yourself, to 'fake' being the correct bulbs, so that the CAN-BUS doesn't mistake it for a bulb fault due to a voltage drop.
He's meant to be looking into it for me, so as soon as I get more details, I'll let you know.
Does your DRL's light up within the headlight or are they within the fog light assy ??Not sure I can comment on this, as my Exeo already has DRL wiring etc. I'm just looking to replace the bulbs with something better.
Swapped over my indicators for Diadems too... Was very wary given some of the posts here, but to be honest it was no bother at all... Having said that I have a 2.0 TSI, is there less space in the diesel engine bay?
Not seen a petrol variant, but the engine bay looks quite tight on mine round the front of the engine.
