They clip in if you start at one end pull it towards you with a pair of pliers and it will unclip then work your way to the middle, do the same the other side, the middle ones can be a pain to get out i had to cut my old one off.When you refit it do the same start at the edge and work to the middle, the best thing to do with the middle ones is use trolley jack and push the splitter in to the holes its areal pain trying to push them in by hand.
Its best to put the splitter on when the bumpers on the car. Good Luck.
