Just used the guide to fix the rear washer (something Seat Doncaster failed to do properly but did offer to have it back in) but while testing the fronts and back found that while using the front washers I have screen wash leaking out of the front wheel arch (just like the rear did before the fix).
Just wondering if anyone knows
1) how easy it is to remove AND replace the wheelarch cover
2) if indeed the front washer pipe joint (I presume) is located in there somewhere and fairly accessible
Just on the rear fix, I could barely get my fingers in to hold the female connector, eventually managed to use angled long nose pliers to hold the pipe and push the male connector in with my hand which took some pressure.
