g60 flywheel vr6 clutch
Ibizaκιας
Newbie
Feb 6, 2006
170
Greece - Cyprus
you are joking right???? if you say that then the car i took it wasnt a vr6 or my car isnt a 20vt..... because i i was there when they took it out from the vr6 golf..
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
That part number shows nothing in ETKA. At best you are mistaken and either way you are wrong. A VR6 flywheel has 10 bolts and will not fit a 1.8t gearbox.
black night01
can u help me got seatibiza cupra 20vt i just got the vr6 clutch g60 flywheel fitted and the garage has phoned me and said it wont go in to gear whats the problem help...
black night01
thanks for the quick reply the garage said thay have done this a couple of times still no luck ....i phoned the clutch place and thay said it is defently the right clutch thay sent me totaly stuck now
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
wont go into gear with engine running?
will it go into gear without engine running, and if so what happens (carefull) when you start engine with it in 1st with foot on the clutch..
black night01
im not 100 percent sure on that. i would of thort he would of tried it both ways but then again he might of just put it back togeather and done a check with the engine off then realised it wont go in gear and may not of started the enngine to see if it made a diffrance thank you ...help
TomTomTom
Mk3 Ibiza Cupra 230bhp :D
Nov 5, 2011
205
East sussex
Why can't I use standard flywheel bolts on my G60 flywheel conversion? I presume because of length? However after a quick test fit they don't interfere with anything when I rotate the engine?
