oh ok. gota try an wire my gauge in on sat. thatl be fun. were bouts do you put the t piece for the boost gauge?? ma m8 at the shop said use the little pipe that comes off the intake manifold?? is this right?
yea the wiring because my gauge has to be on when i switch on the ignition because otherwise i cant c it lol found the 1 telling you were to put the wiring in to the dimmer.. wud this work?
You need an ignition live, that one would work but would dim the gauge to if you dimmed the dash lights, which is the way i would wire it.
