Please tell us that's a typo and you meant to say "2500"?
If you're restricting your revs to 1500 then you're really lugging the engine badly - and that ain't good for it.
My personal opinion is that people tend to overdo this "keeping the revs down while cold" thing. The advice is often quoted on TDIclub, for example - but many of those guys live in Canada or colder parts of the USA. We don't live in a particularly cold climate in the UK, so the oil flows pretty well even in the depths of our winter.
Of course you should avoid high revs when cold, but I don't fret too much about it if my revs briefly go up to 3000 or so as I go through the gears - especially once the temperature gauge has moved off the bottom stop.
yep i agree with this. these are hardy lumps, dont granny them too much else your just sooting them up.
I think in general you can tell if the car is struggling with too low revs as the car will rumble.
i never feel any rumbling when i pull away
car always pulls well in any gear and any rpm speed
With respect if your do 25 mph in fourth gear the car with "rumble" as I call it. By this i mean you will get vibration from the engine struggling to get the car moving. Every car does it if your in wrong gear with low revs.
There's no hard and fast rules about what speed to do in what gear etc. For a start, different models have different gearing, and we all have a different driving style and preferences for how quickly we accelerate.
If you're just driving normally, just change up when the engine can comfortably take the next gear without struggling.
Driving at very low rpm is counter-productive even if it's not rumbling, TDIs are less efficient when running off-boost. Peak efficiency is where peak torque is, when the turbo is happily doing it's job and the ECU isn't having to overfuel regularly to get the turbo back up to speed when it drops off boost.
My Ibiza used to be far more efficient when cruising gently in, say 5th at 1900-2000rpm than it would be if I changed up to 6th and the revs dropped to 1500 or below.
With regards to changing into second - during day to day driving I use first just to get moving then change into second, going any higher in first just makes for a jerkier drive. Unless you're racing someone off the lights...
For absolute max acceleration it's a different matter, it all depends on your engine's power curve. Then you're simply aiming to use the rev range between gear changes that would have the largest area under it on a graph of RPM vs Power. Generally this would mean changing up a little way after peak power has been reached, so that in the next gear your start below peak power, go through it and past again; for most it will mean reaching somewhere between 4000-4500 RPM before each change.
On remapped cars you might be able to go higher, depending on the map and mods, as they generally maintain torque (and therefore power) longer up the rev range, where standard maps often tail off very significantly past 4k rpm.
Anyone else have a short attention span and put your foot down and think oops not warm yet...
mainly after work(I just wanna go home!)
i know a very rare and expensive classis F1 car that has a startup procedure of "hold @ 8000rpm for the first 3 mins" :)
going to add, that i often change up at 1500 when i'm feeling frugal and she never feels laboured or jerky or pissed of at me.
normally change at 3000, but have seen 4000 when in a hurry pulling away
do what feels comfortable and if the car isn't happy it will tell you
