rallycupra Guest Nov 9, 2009 #1 Are the gearbox's the same in a Leon cupra R and the Cupra? Are the ratio's the same?
Shaunyboy Aug 7, 2009 1,395 0 Manchester U.K Nov 9, 2009 #2 Depends on the gearbox in it, if its an 02M wich i think they are if its a 6 speed then yea.
Willie LCR Track car Aug 6, 2004 8,939 1 Sunny Scotland Nov 9, 2009 #3 Same gear ox but not 100% the ratios are the same but would assume so
rallycupra Guest Nov 10, 2009 #4 Cheers guys i thought the gearbox was the same just wasn't sure on the ratio
DPJ ........... Dec 13, 2004 7,995 3 NN Yorks / Salento www.seatcupra.net Nov 10, 2009 #5 Ratios are the same.
adam cupra 20vt Built Not Bought. Mar 31, 2005 6,155 2 Mud Hut Nov 12, 2009 #8 Would the MK4 Golf Anni box be the same?
Andrewcupra TDI Resident Desk Jockey Apr 30, 2008 3,186 2 in the mountains ( Wales ) Nov 12, 2009 #9 could you change the ratios ?? heard people changing differnet cogs from other models as a custom job
rallycupra Guest Nov 12, 2009 #10 adam cupra 20vt said: Would the MK4 Golf Anni box be the same? Click to expand... Could well be but i'm not sure, Would they be the same as the TDI 6 speed box?
flappy Ferociously Rapid Mar 28, 2007 219 0 Nov 12, 2009 #11 I would expect the TDi's to have longer ratios or at least final drive
Willie LCR Track car Aug 6, 2004 8,939 1 Sunny Scotland Nov 12, 2009 #12 The ratios on the TDI 6 speeds are different. The other models with same GB are 2WD 6 speed TT's, MK4 Anniversarys, LC and LCR's
