Gearbox code
monkgti
Slow progress!!
Mar 18, 2007
85
Durham
What code of 02(A) box is in a 2.0 16v Ibiza?
I'm looking at getting a lower final drive (CZM) and just want to be sure it isn't that already..
edc
Blue Leather & Shiny Bits
Feb 8, 2002
8,142
Surrey
www.clairecoileytrust.com
CDA 3.61 from memory. I think there are 3.94 and 4.12 versions out there. RobT had somethign up his sleeve many moons back and Bill has a spreadsheet/calculator with the 02a ratios on it. I had it .. on an old PC so not here any longer.
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
from memory it's standard CDA 3.68 but ill check when i get home
CZM was in the Toledo for 6 months tops in fact i've not got the diff listed :(
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,653
South Wales
have a look on my project thread I have the spreadsheet on there some where.
16v box is 02A and the ratio codes are CDA and like edc said final drive of 3.68. I have fitted the 3.94 FD and found it very good I was in two minds with having the 4.12 but speaking to a few people it was going to be too short and was reading on forums of people going from 3.68 to 4.12 and then to 3.94.
Do a search for the 3.94 FD and I have written a thread on here with all the part numbers of everything I changed.
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
For refrence
020
6 Speed, mechanical clutch
Code Vehicle 1st 2nd 3rd 4th 5th Final 1
GC 4 speed up to '80 3.45 1.94 1.29 0.97 N/A 3.89
GC,GN 4 speed from '81 3.45 1.94 1.28 0.91 N/A 3.89
GP,GL 3+E from '81 3.45 1.75 1.06 0.71 N/A 3.89
GY 3+E Pickup 3.45 1.75 1.06 0.71 N/A 4.17
FO 11/'78-5/'79 3.45 1.94 1.29 0.97 0.76 3.89
FF,FN,FH Up to 07/'80 3.45 1.94 1.29 0.97 0.76 3.89
FF,FN,FH,FJ From '81 3.45 1.94 1.29 0.91 0.71 3.89
FM,FD,FK Close Ratio 3.45 2.12 1.44 1.13 0.91 3.89
6G Euro 8/'82-7/'83 3.45 1.94 1.29 1.29 0.91 3.65
7G Close Ratio, Euro 8/'82-7/'83 3.45 2.12 1.44 1.13 0.91 3.65
2H Close Ratio '83 GTI 3.45 2.12 1.44 1.13 0.91 3.94
4S,AOP,AGS '86-'90 1.6L Diesel 3.45 1.94 1.29 0.91 0.75 3.94
4T,8A Euro From 8/'83 3.45 1.94 1.29 0.91 0.75 3.67
7A From 8/'83 3.45 1.94 1.29 0.91 0.71 3.94
4K Close Ratio 3.45 2.12 1.44 1.13 0.89 3.94
4Y Close Ratio 1.8L 8v 3.45 2.12 1.44 1.13 0.89 3.67
9A,AEN,ACD Close Ratio '85-'89 3.45 2.12 1.44 1.13 0.89 3.67
ACH '85 1.6L Diesel 3.45 1.94 1.37 1.03 0.75 3.94
AGB,2Y Close Ratio,16V 3.45 2.12 1.44 1.13 0.91 3.67
ACN,AON,ASF,ACL 1.8L 8V 3.45 1.94 1.37 1.03 0.75 3.67
AUG,DGF,DGT 1.8L 8V '90-'93 3.45 1.94 1.44 1.13 0.89 3.67
AWY '90 Diesel 3.45 1.94 1.44 1.13 0.89 3.94
AVX 1.6L TDI ECO 3.45 1.94 1.29 0.91 0.75 4.25
CHB,APW,DFN From '93 1.8L 3.45 1.94 1.37 1.03 0.85 3.67
CHD,DFP,ATH From '93 1.9L TD 75hp 3.45 1.94 1.28 0.91 0.75 3.67
CHE,DFQ,DGD,AMC From '93 115hp, Large input shaft 3.45 1.94 1.28 0.97 0.80 3.67
02A
5 Speed, hydro clutch
AGC Corrado 1.8l 16v 3.778 2.105 1.345 0.971 0.795 3.944
AGK Corrado VR6 3.778 2.118 1.458 1.034 0.838 3.389
ASD Passat 16v 3.300 1.944 1.308 0.971 0.717 3.944
ATA Corrado G60 3.778 2.105 1.345 0.971 0.795 3.684
ATB Corrado G60 3.778 2.105 1.345 0.971 0.795 3.450
AYL,AYK Corrado G60, Passat 16v 3.778 2.118 1.429 1.029 0.837 3.684
AYN Corrado G60 3.778 2.118 1.345 0.971 0.756 3.684
CAW Corrado 3.778 2.118 1.458 1.034 0.838 3.647
CBA Corrado G60 3.778 2.118 1.360 0.967 0.769 3.647
CES Corrado 2.01 16v 3.778 2.118 1.429 1.029 0.837 3.684
CGY Corrado 2.01 16v, Passat 3.778 2.118 1.458 1.029 0.837 3.684
CHA Passat TDi 3.778 2.118 1.360 0.917 0.717 3.944
CDM Corrado VR6 3.300 1.944 1.308 1.034 0.838 3.647
CD/ Seat Toledo 2.0l 16v 3.300 1.944 1.308 1.029 0.837 3.684
CHN, CCM Corrado VR6, Golf/Jetta III 3.300 1.944 1.308 1.034 0.838 3.389
CNL Passat 2.0l 8v 3.778 2.118 1.458 1.029 0.837 3.684
02J
EDT Seat Ibiza Cupra 1.8 20v 3.300 1.944 1.308 1.029 0.837 3.389
EKW Seat Ibiza Cupra 1.9 Tdi 3.778 2.063 1.348 0.967 0.744 3.158
EBD Mk4 Golf 1.8T (AGU engine) 3.300 1.944 1.308 1.029 0.837 4.235
ENJ Mk4 Golf 1.8T (2000) 3.300 1.944 1.308 1.029 0.837 3.684
EHA 1.8T (AWP 180bhp) 3.300 1.944 1.308 1.029 0.837 3.824
CZM 2.0L Beetle '98 3.300 1.944 1.308 1.029 0.837 4.235
DQY TDI Beetle, Golf/Jetta IV 3.778 2.118 1.360 0.971 0.756 3.389
EGD 1.8T Beetle '99 3.300 1.944 1.308 1.029 0.837 3.938
DZQ,EBP,EGT,EKG 2.0L Beetle,Golf/Jetta IV 3.778 2.118 1.360 1.029 0.837 4.235
EKH,EMS,EZK,FBV 2.0L Golf/Jetta IV 3.778 2.118 1.360 1.029 0.837 4.235
EBJ,EGR TDI Beetle, Golf/Jetta IV 3.778 2.118 1.360 0.971 0.756 3.389
EBQ,EMT 1.8T Beetle,Golf/Jetta IV 3.300 1.944 1.308 1.029 0.837 3.938
EGQ,FBW 2000-up 1.8T Golf/Jetta IV 3.300 1.944 1.308 1.029 0.837 3.938
DZC,EHC,EGF VR6 Golf/Jetta IV 3.625 2.071 1.474 1.038 0.844 3.389
EWW,FBY,FCF VR6 Golf/Jetta IV 3.625 2.071 1.474 1.038 0.844 3.389
02M
6 Speed, hydro clutch, dual final drive
Code Vehicle 1st 2nd 3rd 4th 5th 6th Final 1 Final 2
tbc Mk4 Golf V6 (?) 3.417 2.105 1.429 1.088 1.097 0.912 4.200 3.316 *
DRW tbc 3.818 2.105 1.345 0.972 0.970 0.806 3.238(?) 2.615(?) *
ERR Seat Leon Cupra R 3.417 2.105 1.481 1.152 1.167 0.970 3.88 3.10 *
* The 02M gearbox actually has two final drive ratios. The first one is for gears 1st to 4th, the second for 5th and 6th.
02S
6 Speed, hydro clutch, single final drive
FYG Mk5 Golf, Touran, A3 3.78 2.06 1.45 1.11 0.88 0.73 3.65
GLB Mk5 Golf, Touran, A3 3.78 2.27 1.52 1.18 0.96 0.82 3.65
GQB Mk5 Golf, Touran, A3 3.78 2.27 1.52 1.18 0.96 0.82 3.65
GQL Mk5 Golf, Touran, A3 3.78 2.27 1.52 1.11 0.90 0.77 3.94
GQM Mk5 Golf, Touran, A3 3.78 2.27 1.52 1.11 0.86 0.73 3.39
GQN Touran 1.9TDi 3.78 2.06 1.45 1.11 0.86 0.73 3.65
GQP A3 2.0 FSi 3.78 2.27 1.52 1.18 0.96 0.82 3.65
GXV Mk5 Golf, Touran, A3 3.78 2.27 1.65 1.27 1.03 0.86 3.94
More to come on this, with more details of what ratios are in which gearbox variant...
02A & 02J gearbox differences
# The differentials are different. The 02A has push in output shafts on spring clips, whereas the 02J has bolt in output shafts but they are interchangeable as long as you have the correct flanges.
# The crown wheels are the same, but the planet gear/LSD bit that differs, which means that the Quaife LSDs that fit these boxes are different
# There is no difference in the holes that bolt the gearbox to the engine or the starter into the box, - the only difference is in the lower part of the bellhousing where some cars have a (pointless) girdle on that bolts to the underside of the sump.
# The 02J has bigger support webs around the differential area
# There is a slight differences in the fixing points for the gearchange cable support bracket
# The two mounting holes at the wheel end are slightly different as well. They are threaded on an 02J gearbox, whereas they are just holes with an 02A
# The bell housing face that mounts to the block is slightly different
# The selector shaft is different, there are two options; either swap to an older selector shaft, or use the 02J selector shaft with a Mk4 Golf shifter box.
# The 02J boxes out of a 1.8T, the axle flanges are 108mm as opposed to 100mm, so it'll require either custom axles, or swap the axle flanges.
# The 02J 100mm axle flanges part number ends in D, all other 02J axle flange part numbers are 108mm.
02S the 02A replacement?
The research suggests that the 02S found in the Mk5 Golf, A3 and Touran appear to be an 02A/J with an extra cog. It seems that VW have produced a 6 speed without the dual output shafts.
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
Its from an A3.. CZM
ahh got ya - was so rare in a SEAT i reckon it never made production line
anyway if it helps any A3 CZM = 72/17 = 4.23
confirmed from list above also
CZM 2.0L Beetle '98
1st 3.300
2nd 1.944
3rd 1.308
4th 1.029
5th 0.837
diff 4.235
Dave_R
Sep 20, 2004
3,653
South Wales
where's my threads gone about this? I did a nice write up with all the part numbers to, did a search but nothing.
Have anyone done a clean up or something?
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
I have a feeling the Search database is playing up Dave, took me ages to find my rattie thread too this am, wouldn't show up on search at all
monkgti
Slow progress!!
Mar 18, 2007
85
Durham
one problem, what engine or ecu mods have you done?? Cause an ABF only revs to 6900rpm
Ha...Just shows I'm a bit rusty...
Was 15 years ago since a I had a good KR 2.1 valver..(which had the limit raised to 7600)
Never mind still quick enough for me .and quicker than **** black concours ones...(leeattley13[B)])
R French
"The research suggests that the 02S found in the Mk5 Golf, A3 and Touran appear to be an 02A/J with an extra cog. It seems that VW have produced a 6 speed without the dual output shafts."
This looks like the holy grail - any idea if a direct fit? Combine this with a 4.24 diff and it will be a cracking box. Was having problems with the steering lock on dual output boxes!
Cheers, Rich
