Hi All
I've had a problem with my Ibiza since April where getting it into 1st gear and the gear change between 1st and 2nd is really tough.
Another symptom that developed last week was when in reverse gear, you could hear something spinning down (presumably in the gearbox) after reversing and putting the clutch in.
I've reset the linkages a couple of times and it made no difference and it has been getting worse so I took it to a VAG specialist in my area last week and got him to take a look at it.
First diagnosis was that it was the selector turret that needed replacing so this was duly ordered and fitted but as of this morning the garage have phoned and told me that this hasn't solved the problem and that a gearbox strip down is needed to find the problem.
Has anyone here ever had similar problems? (It's a 2005 ATD engined 1.9tdi)
