Gearbox
kirsty1marie
Hi to everyone,
I really need some advice I have an R reg kiwi green cupra sport GTi 2 litre 16valve and my reverse gear has totally gone.
I've got a replacement gearbox but what i need to know is there any special tools i need to take the old one out and put the new one in. I'm quite new to all of this ive done minor things like oil change, air filter, oil filter, brake pads, spark plugs and wishbones. But this is a big job, unfortunatley I'm not in a position to be able to pay someon to do it so it will be me in the garage.
So all tips and advice would be a godsend.
Im getting to the stage of should i just scrap or sell the car
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
spline fitting for the drive shafts and rest is just basic tools and patience really
i always remove the outer mountings and twist em up to get em out easier
kirsty1marie
thanks for the response, but no offence to other girls but i have no idea what that is, where can i get one from
"spline fitting"
kirsty1marie
plus do you know the exact size of the nuts ir is there anyway i can find out?
Undert4ker
Like Ibiza_95 said, M8 is the size you need, you should be able to get spline bits from anywhere that sells car/hand tools, Machine Mart do a set for 29 quid with more than you'll ever need. If you can get a long shaft bit like the ones in the MM set it'll make life easier as there's not much space next to the bolts.
Most essential tool for this job has to be a second person as it's a pain refitting the gearbox and getting everthing lined up, seems to go on at a strange angle. Or get an engine crane & take the whole lot out :)
kirsty1marie
thank you for your help i just wondered if they did different mm like a socket set i suppose
ibiza_95
1.8T MK2 Conversion
to get the gearbox off, leaving the engine in you should only need... (dont quote me)
10mm socket
13mm socket
17mm socket
19mm socket
Flat screwdriver
Hammer
M8 Spline tool
Its a fairly easy job to get it off... getting it back on is the ball ache part... deffinitely need a couple of strong people to get it back on...
also its a fair bit of lying on the floor, and in this weather its a bit crappy...
just consider that i paid 60 quid to have a gearbox swapped over on my old 1.4
if its going to take you a day to do it yourself you may aswell just put yourself in for an extra day over time, earn the 60 quid in the warmth, and pay someone else to do the work in the cold....
just a thought
kirsty1marie
i was made redundant then suffered 3 strokes had 4 lots of surgery on my womb in the last year and that many cardiology appointments ive lost count.
but if i knew someone that would do it for £60 then id go with out for a few weeks, so if you know anyone that would please send me details
ibiza_95
1.8T MK2 Conversion
where bouts are you from?
i know a guy in wakefield....
also... give some of your local back street garages a bell and see how much theyll do it for...
as a rough idea i paid 60 for the box and 60 for fitting... also got a clutch i think at about the same kind of price 60 ish
