FASTER
354
Nottingham
any body fitted golf mk4 shocks ont there leon! im looking at some s/h coilovers by fk off a golf mk4 and was wondering if they would fit? i think the chassis is the same! thanks
My FK Highsport coilovers apparently are identical to the mk4 golf version.
However, there are several versions - if you have a cupra R then they will NOT fit. (different front end)
If you have a CUPRA, then you need the FKSE61 kit (for 911kg or heavier engines)
If you have a std leon then you need FKSE60 kit (for engines under 911kg)
Hope this helps
physically they will bolt on. however it's not likely that the spring & damper rates will suit the car as well as you want / need
