I have seen your and yes it's mahhhoooosive, not really sure i've got enough room for a bad boy like yours.
Jetex have a 100mm neck filter supposedly good for over 800bhp (ER-10003)
£68.....Measures in at a svelt 190 x 282mm
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
£68.....Then I'll just leave it with that!I didn't even think about the torsen system as the haldex is what's used in the Leon 4's / R32's S3's etc.
Sounds more like it! Did you read up on them? They're not as pricey as well I guess? I could have used a piece like that my self!There is a SQS manual adjustable haldex controller that you can fit to lock the diff all the time. There is a version of this available that has a handbrake cut off switch that opens the diff.
Now this should be interresting.supercopa
So i've had an awesome day today and finally managed to source a Seat Sport Supercopa rear spoiler....
cracking work pal should be a right animal. you had best lock your pets up when you start it or you may get minced cat insode your turbo when it gets sucked up by it!
one thing thats confused me is why did you replace the for rather then just bolting everything onto the exisiting one
have you ever considered a arc intercooler? they can handle the power you are after and a maffhugeass
keep up the top work![]()
Jetex have a 100mm neck filter supposedly good for over 800bhp (ER-10003)£68.....
Measures in at a svelt 190 x 282mm![]()
i will use the controller from crc-performance.com (i have not enough posts to post the link). If you need some help for translation let me know.
Now this should be interresting.![]()
saw this graham and taught of you
http://www.ebay.co.uk/itm/SEAT-Leon...arts_Vehicles_CarParts_SM&hash=item256bd69259
How to ruin a carbon splitter paint it white
Exactly what I was thinking!
Graham the filter was a Green Cotton one, made by Green Cotton![]()
Graham you a legend for what your doing with your car I can only dream of having the skills you have sir. Massive respect
This car just gets better
Are you meaning why did he replace the floor?
It's because the standard FWD leon floor wouldn't allow him to fit the necessary bits to make it 4WD.
Sorry to hear about the delays graham, I'm sure once your mrs gives birth your child will become the most important thing in your life. My mrs wants to get pregnant soon too, but it does meen I can keep number 1 spot at badger5 for a while
