Blanco92
www.racedriversinc.com
Apr 11, 2010
2,495
Bournemouth/Cheshire
Hi all,
My Ibiza has developed what sounds like a grind all of a sudden on full lock, whether it's in 1st gear or reverse.
I've had a look round, can't see any visible marks from any grinding. :shrug:
The car isn't lowered, and is on standard size 205/45/16 tyres.
Anyone else experienced this?
Thanks for the suggestions lads.
I've since found out that it's not suspension related, more steering related. When I turn to full lock (when stationary or moving slowly) and hold it there, after 5 secs or so the grind noise comes and continues until I straighten the wheels a little.
I've checked my power steering fluid and topped it up a little, car seems the same as it was before.
I also remembered it has only done this since I adjusted the steering weight with VCDS. Perhaps I should change it back and see if the problem goes?
i have this problem on my 1.4 when i have it on full lock reversing or goin forward, i can feel it drag alittle aswell but i cant see any sign of rubbing, but my car is slammed but normal wheels n tyres but no marks in the arch or on the suspension ?
