does it turn over??? just not fire???
coil or crank sensor most likely, one is easy to do, one is not
soooo...does the engine turn over or not then?
Remove all spark plugs and check teeth to see if they have petrol on, or are bent. Also you might need a new rotor arm on your dissy cap if nothing is sparking, so check that as well.
there is no spark to the spark plugs, It's as if there is no battery but I have checked the battery
They they will do if your battery works, but if you dont get any sparks like you say, then your engine can't start up.
