GUIDE: The Mk2 Leon VAG-COM Guide
rebel69
Dark Matter Power
Dec 10, 2009
83
Kent
lights
I dont have auto lights but do have a the large multi function display.
Coming home lights worked from that but Dan gb enabled the leaving home lights via his VAG com.
What happens is if you leave the light switch on all the time the lights will switch themselves off after xx seconds (depending what time you set) when you leave car and turn back on for xx seconds after you unlock the car.
Have been trying to build a auto light circuit but Seat wiring is very complicated due to the canbus.
Hope this helps
Craig01988
21
Thanks I'll have to see if I can find someone with the right lead or buy one for a reasonable price, $250 seems a bit steep :think:
humza123
has anyone got a vag-com in birmingham if so can you pm me thanks
bengreen0687
Do you have the engine coding for a 2006 manual 1.6 petrol Leon? I have set it to 1 by accident and now the car is REALLY playing up. Please help.
mrbubba
463
This is driving me nuts. I've tried to turn on the "Chirp" when locking and unlocking the car, I've changed the correct options as per the instructions, clicked on Do It and its accepted, yet when I go back into that module, its back to what it was previously.
I've got a Leon Cupra MY08
mrbubba
463
I managed to turn the seatbelt bong off, but still can't change the alarm to chirp when activated or deactivated.
There is an option that says something like "Prevent alarm horn changes" or similar and I've taken the tick out of that, yet its still there when I go back in.
Stig555
131
Can the windows be closed with just a quick click of the key rather than holding it down?
boditza
67
Craiova, Romania
for a mk2 from 2008 without memory seats is it possible to make the mirror go down when in reverse??
and also for leon mk2 does anyone have Emergency Brake Flash activated and working?
1,044
North East, UK
EMERGENCY BREAK:
You mean when you pound on the breaks the hazard lights come on??
Yeah i have this enabled and it has come on for me once!!
boditza
67
Craiova, Romania
i slammed the brakes on gravvel for test and nothing came on.. the car didn't stopped but on a mondeo mk4 the hazard lights were on as long as the abs was working so i figured it should be the same on mine
on newer models it flashes the brake lights.
honkifyou
229
Plymouth
Hey guys. I've been playing with VAG-COM all day, and I've managed to get Needle Sweep and the Locking Chirp but having problems with the Leaving Home Function. I have enabled it and have the options menu in my MFD but they won't come on?? Any ideas??
mrbubba
463
Don't forget to set the time (its in adaptive section)
Sent from my Desire HD using Tapatalk 2
