Aviry
80
I know this subject was talked about over and over again but...
found some new Bulbs which should be much better then normal leds everyone used here:
They are 15mm more then the normal ones, will they fit?
for compression:
VS.
Specs:
http://www.superbrightleds.com/specs/H3_11-WHP.htm
where to buy:
http://www.superbrightleds.com/1157.htm
well? what do you think?
i doubt very much they will be much brighter tbh!
but as said why not have a go! ;)
the increase in lumens (light output) is from 25 to 40 which is an extra 40% on the 9 led version, so they should be almost twice as bright when compared to the single led version...but thats not going to make them useable as fogs...i have the standard single led version, and they are great as driving lights to compliment the sidelights, but can't see this 9led version being a huge amount better.
although if i hadn't bought the single version and had seen these first, i'd have gone for the 9 led version...so i say give them a go m8!
im not sure if they are not to big (45mm)
and now sure about the color too...
well put it this way guys... I have HID bulbs in my fogs, which are a fair bit longer than a h3 halogen bulb! ;)
