Well it's been along time since i've been active on here!
Never sold that car after all so i thought I would update this thread.
I sort of lost interest in the car when I came back. And during my final year of uni I had very little time to spend looking after the car so it started to roughen up a bit. With uni out of the way and the masters degree in the bag I set about giving the car a makeover.
I sold off a lot of parts, body kit wheels sound system etc.
While the car was getting painted I saw a set of wheels advertised that where local to me and at good enough money. So picked them up and split them ready for a refurb.
They where 5x114 so I got the bolt holes drilled out to accommodate wobble bolts
rays engineering sebring gt-s:
I got the car back home at about 6pm on the night before GTINI Castlewellan so had a mad panic getting the car cleaned and wheels fitted for the next morning. Then I hit a
problem. The wheels didn’t sit right. The fronts were tucking and the rears poking a lot more than I had calculated. With the rear wheels catching the arches I decided to raise the rear 20mm in order to get it down the road so I could see the show.
After a mad week of work and house moving I decided to tackle the wheel fitment issue. I removed the wheels and measured them to find that the wheels where et17 rears and et58 fronts when then should have been et37 rears and et38 fronts. I became obvious that someone had change the front and rear wheel centres around in the past when changed the offsets. I really should have checked this before I rebuilt them but I was in a mad panic to get it done. But lesson learned for the next time.
So split the wheels again and changed the centres around.
The wheels are sitting much better now and pretty much how I thought they would have day one
Front before:
Front after:
Rear before:
Rear after:
I took the car down to the weight bridge to get a level surface to set the suspension height. So the car is sitting exactly how I want it for the mean time.
