Am I glad I found this thread ! It's so much easier to say "known
problem" than explain just how I know I can't have left the handbrake off !
This evening I parked my car (Leon ST 1.4TSi) on my driveway as usual, reversed up to the garage door. The driveway has a slight slope down away from the garage. Well, enough slope that I can't possibly leave the handbrake off, as it will move immediately.
So I got out of the car, opened the hatch, let the dogs out, shut the garage door, and 10 to 15 minutes later heard an alarm. Turned out to be my car, only rolled about 6 yards but picked up enough momentum to break a concrete fence post and make quite a mess of my front bumper. I believe the handbrake was fully off when I found it, hence the momentum.
My first searches (not SEAT or VAG specific) suggested that applying the handbrake when the brakes are hot can lead it to loosen as it cools, but I had driven less than 1.5 gentle miles after walking the dogs. And anyway, I think I had found the handbrake lever
down after it moved.
Now I had already been a bit cautious about the handbrake, from new (5 months ago) it was quite hard to get it past the first click, and too easy to leave it sitting not properly engaged on the ratchet. But these days it's a bit looser, two or three clicks is normal, so I suppose I was lulled into a false sense of security. But I guess it hadn't dropped properly into the ratchet and had jumped clean past the last one or two ratchet positions when it decided to let go.
Over the years I developed the habit of
not leaving cars in gear, because with multiple drivers one doesn't know if the next driver will expect to find it in gear (oops !). But now we are forced to press the clutch to start the engine it makes perfect sense to leave it in gear. It's in gear now, just wish it had been earlier this evening
I do like Rydale13's suggestion of putting a foot on the brake pedal as the handbrake is applied, this does seem to get the handbrake on a bit harder with no more arm effort. Especially valuable as SEAT left the handbrake where the driver in the LHD version would expect to find it (i.e. a long way from the driver in a RHD car). But this instruction is
not in my handbook.
I'll add my own tip - never press the handbrake knob when applying the handbrake. Pressing the knob doubtless minimises wear on the ratchet, but from now on I really want to hear it click, for confidence that it has properly engaged with the ratchet. Though I guess that it might still be possible to leave it perched on the peak of a ratchet tooth with an extra bit of pull. It's really disconcerting to know it can bounce past subsequent ratchet teeth when it lets go.
I'm aware that others are reporting that the handbrake was still on after their cars had moved, I'm thinking that in that case the handbrake was left not quite engaged with the ratchet and has dropped back to the next notch. I was unlucky enough that there weren't many notches left to jump to, and it skipped past them.
Finally, I'm a bit confused by the mention of "hill hold", I wasn't aware I had it but maybe I have. How might that lead to a
problem 10 to 15 minutes after leaving the vehicle ?
