Really? Have you got tyrannosaurus rex arms?Especially valuable as SEAT left the handbrake where the driver in the LHD version would expect to find it (i.e. a long way from the driver in a RHD car).
Finally, I'm a bit confused by the mention of "hill hold", I wasn't aware I had it but maybe I have. How might that lead to a problem 10 to 15 minutes after leaving the vehicle ?
Really? Have you got tyrannosaurus rex arms?![]()
I'm not a body builder if that's what you mean !SEAT told me 7-9 "clicks" are needed to fully apply it.
And the fact it seems to work seems to say that there is no separate drum brake for the handbrake, it's all down to the discs.
...I do like Rydale13's suggestion of putting a foot on the brake pedal as the handbrake is applied, this does seem to get the handbrake on a bit harder with no more arm effort... But this instruction is not in my handbook...
I've had conversations with two separate dealerships regarding the handbrake, both have told me that the handbrake operates inboard drum brakes within the rear hubs.
That said, I've also got very little faith in SEAT dealership's ability to do anything beyond selling cars to people, let alone answer technical questions, so I will happily be proved wrong.
My issue is a graunching when applying the handbrake. Feels like the inner cable is rubbing on the outer cable.
Took it into the dealer who will look at it under warranty. I'll report back
worried now that it could be the same issue you've all had??
