TSL 333
Company car arrived so selling up!
May 13, 2008
85
Glasgow
Is it easy to change the n/s (passenger side) headlight bulb; what needs to come out first?
Had a bit of a hangover on Sunday when I was going to change it so it looked harder than it was!!:redface:
you'll need to remove the air duct thats screwed in and maybe the battery cover depending on how big your manly hands are ;)
other than that, its easy!
what about the sidelights, ne easy way of changing them?
But do not pull the wires for the sidelight connectors... I used needle nose plyers, bit fidley but managed it, the sidelight ones are sometimes stuck well in if they havent been changed in a while. If you look at how to do the drivers side where theres more room to see before you attempt the drivers side it may give you a better idea?
While on the subject can anyone tell me what bulb I need for a full beam lamp?
Just had to check this thread!
Tried pulling but they're proper wedged in!
So i wondered if they were twist lock ones., just pulled on them with some pliers!
