i cant find any info on how to do this.
the heated part has 5 wires coming off the plug. 3 brown one back/white and one black/yellow.
i assume the brown are earths but no idea on the rest...
and also as said before these are temperature adjustable, or was that just a fancy switch?
could i simply get these to operate on/off and not on a scale of 1-6 etc?
would i need to run a fuse to these?
on another note im fitting a boost gauge and could really do with knowing which wire behind the lights switch panel is the ignition live. i want it to come on with the ignition and not the headlights
thanks
the white/black is one cable, as is the black/yellow
this is all so confusing.
you only need a positive and an earth/negative right?
so one of those is probably the positive and maybe the other one is temperature control?
why did i do this again? lol
I doubt it will be as simple as fitting a switch to operate your heated seats. I am pretty sure the Audi would be fitted with a module to control the heaters and there will be a sensor built into the seats to measure the temperature.
If you simply apply power to the heating elements in the seat you have no way of controlling the temperature. They will just get hotter and hotter until either the seat or your rear end gets burned.
Try asking on the TT forums for a wiring diagram.
Cheers guys
No Ibizas came with heated seats afaik
Have put a post up on the TT forum but don't hold out much hope, can't see me getting these working
Nope you have to make brackets which I haven't done yet.
Have got the heating element working tho, just need to wire in a button and fit them :)
basically its a variable resistor like a radio dial. it variesa the amount of resistance put through the circuit so the more you resist the less power is going to the heating elements :D
That makes sense, although at the moment I would say the seat isn't really hot enough anyway and would want to increase it rather than decrease.
Maybe it isn't coming on full wack like I thought it might
