help.....again
beefy
114
Would Audi S3 alloys fit my 2003 SE TDI Cordy?
They are 5 stud (which my car is) and have a stud diameter of 100
The tyre's on the car are 225/45/17
I dont know anything about alloys so any advice would be appreciated
beefy
114
It doesnt specify the offset, how do I find out what it is and whether it would fit my car?
beefy
114
offset is ET32.
The guy said they fit leon's, toledo's and ibiza's so I can only assume they fit Cordoba's
beefy
114
would these alloys fit a 2003 cordoba se tdi?
They are from a Leon Cupra R from around 2003
Rim width - 7J
Rim Diameter - 17 inches
Offset - 38
Number of studs - 5
Stud diameter - 100
Tyres are 225/45/17 which I would change again
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
yeah they would fit also, however the cupra R alloys are 18", so they must be the 5 spoke cupra alloys @ 17"
beefy
114
Ok 1 more set
A set of seat sport alloys
Rim width
18 inch
51 offset
5 studs
It says it will fit new leon, altea etc
would these fit a cordoba?
Thx in advance :)
beefy
114
what exacty is the offset and what are spacers?
sorry for being a newbie :/
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
AFAIK
The offset is the measurement from the hub to the outer edge of the wheel, therefore a higher offset will make the wheels sit too far in the arches and may catch the brake calipers and a smaller offset will maket the wheels stick out of the arches...
Wheel spacers go between the hub and the wheels to make a higher offset wheel sit further out [i.e bring the offset down] maybe to clear the brakes or something...
Hope This Helps You
beefy
114
so is it ok to buy allows with a bigger offset and just use spacers or would u not recommend it?
I really like these alloys and would defo like to have them on my car. If it is not a good idea though I will forget about it
