what happened to the red\grey cable then ?.............iam going to be dreaming about cables and colours all night now, lol
Ignore it now, it never existed
and lol
Ok it's not that one mate.
what colour is number 14 looks like a capital Y with a bit sticking up the middle.?
You need to see what colour it is under the aerial base then, the trim pulls down easily it's tight but will pop off.
Then you can get the colour for the amplifier.
No choice now, but to get a circuit tester disconnect it from the aerial and try each wire.
Or get a booster lol
12v with ignition tbh is the easy way out![]()
No problems mate
Yeah just goes in between your aerial connector and the headunit, then 12v+ easy.
Connections to the black connection block are listed as
1 - blue/white - Gala (Volume adaptation)
2 - green/grey - Mute (telephone)
3 - grey/white - Self-diagnosis / cable K
4 - yellow/red - Connector for the ignition and switch off with the ignition key (contact S)
5 - red/white - Anti-theft security system control signal, SAFE
6 - grey/blue - Lighting (terminal 58b)
7 - red/white - Battery + (terminal 30)
8 - brown - Battery - (terminal 31)
Connector layout:
1 3 5 7
2 4 6 8
